[Help] USA 120V - voltage converter
alamakazim
Yes it will work
This is a lesson learnt, save on US online store, but waste on the need to buy transformer and lack of warranty
MoneyFace =p
Yes it will work
Yeah it is always a MUST to check for electrical input specification. Must have the 110~240V input to give green light to buy.
Koenig168
I seriously doubt that small little transformer can handle 1500W output. At 230g, it is just a toy. My 500W transformer weighs 1.7 kg. My 3000W transformer is easily more than 10 kg.
epos
You need at least this to convert 1500W of power
NT-1500
http://heanlee.com.sg/products-new/adaptor/
jeffrey159
not sure if i should buy that to test it out or not :s11:
wwenze
mosmos
High Honorary Member
buy one with double wattage rating, usually the manufacturer over rated their products~
