[HELP] video card problem
bumdssa
hi all.
few weeks ago my screen would turn pink when i'm using the computer halfway and it got worst after a while.
when starting up, there will be pixel lines all over the screen.
initially i thought it's the problem of the monitor but after changing a monitor and cable.. problem is still there.
i disabled the video card and everything was okay but recently, the pixel lines when starting up reappear and in windows, there are blues lines all over.
what's the problem here?
thanks in advance! :)
ahbard
Think the hardware too old liao....That's why when u changed to iGPU, it is okay. but the lifespan is short as always stressed out.?
iKoori
1. OS Corrupt
2. Monitor Prob
3. Hardware too old liao
4. Idk liao @.@
bumdssa
yeap. when i changed to IGPU, it is okay but recently the blue lines appeared in windows.
i just changed back to GFX and everything works fine like before. now i'm confused. dont know whats wrong.
ahbard
Monitor the gpu thermal...I think it will give u the same problem very soon.
melovelinux
i would suggest you to do a mem test on your ram sticks
if everything is ok with the ram den is most prbly is ur GPu and mbo cui
try with another gpu see if the problem comes back if it does then the mb is cfm bad liao
bumdssa
how to do mem test on ram stick?
wah. i just changed my mb last year. dont tell me so fast cui :(
Lethal
Hi, is ur motherboard MSI P35 NEO2-FR?
How do u manage to use IGPU if ur motherboard doesn't support onboard graphics?
bumdssa
nope. i changed my motherboard last year. using biostar g31m now.
