[HELP] Web browsing and web gaming system
diamond96
Looking for a web browsing and web gaming system.
Will be using for normal games like
viwawa games , wahjong etc.
Web browsing asiaone , etc.
Currently looking at
Asus P8H77-V LE
i3 - 3220
4GB RAM
Samsung 840 120GB SSD
(Don't need HDD since I don't save movies on it.)
Seasonic S12II 520W OR M12II
(Pls Advice)
Thermaltake V3 BlacX Edition Casing
Samsung 24X DvD-Writer SATA
Windows 7 Home Premium
Is graphics card needed or onboard graphic will be good enough ?
Have my own monitor , keyboard and mouse.
Anything else is needed ? Or need to change ?
summer_dell
nope. hd2500 graphic in the i3 3220 is more than enough to run HD 1080p video and play facebook games and viwawa games
hd2500 comes with directX 11 support, shader Version of 5.0 and openGL Version of up to 4.0. Source : Intel website
you may wan to scale down your psu to just 300 watt in which fsp oem 300 watts is good and cheap ( 36$++)
also, i think u can choose a smaller case since you wont need hdd and gfx.
my 2cents.
diamond96
my 2cents.
Will the FSP PSU be reliable ?
Would get a 'ready' for additional GPU in case I want to add in like a GTX 660
Also which casing would you recommend to fit the Motherboard in ?
summer_dell
I bought one for to power up my dad's com and it had been 7 months. still going strong.
I read somewhere in this forum that the oem fsp 300 watt is 80+ bronze just that is was not certified.
What would your budget be ? I could help u to save even more, if your main purpose is for web surfing and viwawa. For a start, u may consider g2120.
diamond96
Would stick to the i3-3220 minimum.
With a budget of $800 possible ?
Got a GTX660 on my other comp , so if i'm changing that would just put it over to this system. So will need a decent PSU to power it.
summer_dell
oh well,
i3-3220 + Asus P8H77-V LE = $311
4gb ram kingston 1600mhz = $43
Samsung 840 120gb ssd = $159
seasonic m12ii 520W = $99 (semi modular will make your cable management sweeeter)
Thermaltake V3 BlacX E =$65
Samsung dvd =$25
Window 7 home premium OEM = $120
Total set you back by $840 buy and build at pctheme. You can try trade pac for cheaper pricing.
Alternatively,
You may want to swap to
i3 - 3220 + Asrock h77pro 4m = $ 281
to meet your 800$ budget.
diamond96
oh well,
Samsung dvd =$25
Alternatively,
Hmm kk thanks :)
If I were to get the Corsair RAM and use only 1 piece of the 4GB RAM , will it be ok ? Or it must work 2 X 4GB ?
My other PC need an additional stick also :o
summer_dell
Hmm kk thanks :)
haha ... a corsair vengeance performance ram would cost you about $99 bucks.
They usually come in kit form ( meaning 2pieces in a set or even 4 pieces)
Yes. you can just slot in one 4gb ram. you can buy a kit and slot one into each computer. shouldnt be a problem.
but remember , anything more than 4gb, remember to buy 64bit OS.
ie. 8gb (quite common ) will have to go with 64bit os.
diamond96
Ok thanks :)
