Help with build
Funday
Hi everybody , i am trying to build a PC for the 1st time, it is for gaming and school work. My budget is around 1.5K. I have done a bit of research and this is what i have now for the build,
MotherBoard + Processor (PC THEMES)
MSI B350 mortar + ryzen 1600 $468
Graphics + POWER(trade pac)
Either :
MSI GTX 1060 6GB + coolermaster 550W $485
ZOTAC GTX 1060 6GB + seaspmoc 620W $ 448
RAM (trade pac)
Kingston 16 GB $158
SSD (trade pac)
Kingston 240GB $103
HARDDISK (trade pac)
SEAGATE 1TB $68
CASE
wireless card
i have a copy of os , any guide/advice would be greatly appreciated. Thanks .
gld998
Graphics + POWER(trade pc)
Either :
RAM (trade pc)
Kingston 16 GB $158
SSD (trade pc)
Kingston 240GB $103
HARDDISK (trade pc)
SEAGATE 1TB $68
CASE
wireless card
later go down SLS no stock la simi ** excuse, wait here and there. good luck. PC Themes ok. If Trade pc or tradepac, good luck to u
singupingu
Just get everything from Tradepac but beware of the prices. Get familiarize with the pricing around SLS before heading there.
Otherwise, pay a bit more at PC Themes. Much better store, more honest, recommendations are not bad.
WLAN card - TP LINK Archer T6e but the drivers don't auto install. So you might need an external DVD to install the manufacturer one before updating it. Or download it to a thumb drive first so you can install once OS is installed
Chassis - Tecware F3 Elite. Cheap and good looking. Just cable management a bit hard. That's all.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
dgenex
Might want to get better PSU such as EVGA G3/Superflower Leadex Gold Series.
550W is enough for a 1060 or even 1070.
Casing Tecware F3 is best for budget. If want better ones can look at Fractal Design Define C/Mini C or Phanteks P400TG. (Around $130 iirc)
Also can note that if you getting Ryzen, RAM speed does help performance, so if you have extra budget leftover can invest in higher speed RAM.
