Newbie here,
can someone recommend me which part to choose?
the rig is mainly use for gaming, like skyrim, saint row. at 1920x1080 resolution
Budget is 1.5k to 2k. only for the desktop.
Thanks Guy
CPU & Mobo: i5-4570 & Asrock H87M Pro4 @ $368
Ram: Kingston 1600mhz value ram 2x4GB @ ~$84
ODD: Samsung DVD RW @ $22
HDD: Hitachi Deskstar 1TB @ $80
SSD: Plextor M5P 256GB @ $289
GPU: Gigabyte GTX 770 Windforce @ $650
Case: NZXT Phantom 410 @ $154
PSU: FSP Platinum 650W @ $142
Total: $1789
Buy and build at Tradepac.
looking to build a new rig as well.
any shop staff please pm me if you happen to see this post.
Sorry to say this, but they dun do that.... Make your own parts list and bring it down to them.
you are asking to be chopped
look at the price list and select the parts and go down and ask them fix up for u
strange. i remember they used to do that. at least from a certain few shops.
of cos, it's just for a reference check becos i m no longer as pc savvy as u guys. still, will be going down to get the parts after some checking and reviewing.
