Help with gaming rig (BF4, RomeII)
guoscape
Hello,
I am about to build my own gaming rig and I need help in finding the correct components. I am planning to play games like Battlefield 4 in Ultra and Total War: Rome II in similar graphic settings. On top of that I may be interested in using Fraps so I may need better components for a higher playable framerate.
Can anyone recommend me any system builds that costs <1.5k. Is i7-4770k worth compared to i5-4570 which seems to be the hot processor around here? I prefer Nvidia to Radeon too. Dont need 120Hz or 144Hz monitor too.
Jian19
1.5k is too tight for i5-4570 unless u wan to drop ssd out of ur system..
Possible with ivy build
With nvidia it's even more difficult since ur budget can only include gtx760, which can't play bf4 @ ultra maxxed above 60 fps..
guoscape
Then without my 1.5k budget, what is the cheapest build available? Then Radeon leh? I just prefer Nvidia cos of the features but if Radeon is worth a lot more then I will have to go with Radeon. Besides, BF4 supports Radeon graphics this time
voiceoflove
if u like nvidia go for lower card lor, for me i don like nvidia haha
its all personal pref
Jian19
1.5k ~
i5-3350p + Asrock b75m dgs ~ $271
Adata 8gb ddr3 ram ~ $85
Wd blue 1tb ~ $78
Corsair force LS 120gb ssd ~ $141
Gigabyte 280x ~ $431 (bizgram ask tradepac match price)
Superflower hx 600 ~ $109 (mynextcom ask tradepac price match, or u can get both gpu and psu @ mynextcom)
Sharkoon t28 ~ $84
Win7 64 oem ~ $115
Lg ips234 ~ $215
Total ~ $1530 buy and DIY @ tradepac ask for discount
royfrosty
1.5k can be done with a monitor but not 4570. 4430 is posible with an entry level mobo and no ODD with a budget ssd.
Asrock h81m dgs + i5 4430 ~ $ 295
ADATA 1600mhz 8gb Ram ~ $ 85
Wd blue 1tb ~ $ 78
Silicon power v60 120gb ~ $ 120
Gigabyte r9 280x 3gb windforce 3x ~ $ 431 (bizgram)
Cm 311 ~ $51
Superflower hx600 600w 80 + gold efficiency ~ $ 109
Windows 7 home premium 64bit ~ $ 115
Dell s2340L 23inch ips gloss panel ~ $ 215
Total $ 1499 buy at tradepac. Diy and gpu at bizgram.
AS1
It all depends on the quality you intend to play it with.
Most $200-ish cards can get respectable frame rate with it though do expect a performance hit if using fraps. A 650Ti would be a good start and the Radeon 7950 are reasonably priced compared to the GTX 760.
guoscape
Will an entry-level motherboard affect performance. I may wanna up my budget to 1.7k to fit in a better cpu
royfrosty
No performance difference. Just that you will be getting 2 ram slots instead of 4. 1 gpu support instead of 2.
If you up to 1.7k you can consider a better gpu and a msi b85m g43 + i5 - 4570 ~ $ 356
Gpu can go for gigabyte r9 280x 3gb ~ $ 445
And a superflower hx600 600w 80 + gold efficiency ~ $109
And possible to get a better chassis.
