help with GTS 250
dude1991
hi my gpu GTS250 fan broke while i am cleaning it,can u all recommend me any cheap n reliable cooler or fan. or anything i can do to salvage it cus the damage fan cus my whole rig to vibrate.
mav3rick
no pt to repair. just get a new card within ur budget, or take a look at the maketplace...
cKm
Can try using a cable tie and mounting a casing fan onto it.
onionaut
Show us a pic of your 'broken' gfx fan?
Perhaps you can try removing the fan power cable to stop it from spinning and like what cKm said attach with a case fan
Something like below:
ahwei91
you can get replacement fan at sim lim tower ..... cheap !!
wtfh4x
You take out the plastic thing right? Underneath got the metal heatsink? U just cable tie on top. Across the back of the card in X shape through the screw hole of the fan. Go behind the card. Can use two cable tie attached to one another as one may not be long enough.
