Help with keyboard restarting PC
necrophobiaz
Please help me as my computer keep on restarting itself whenever my rosewill rk-9000re keyboard is plugged into the com.This also happen when i plug it into my mac.
It was working fine but recently this happen and the keyboard is not working, as in the led in the num lock is lighted but unable to input as key into the com.
Should i format my com first or RMA the keyboard as i do not have a spare keyboard to test.
Any advice is appreciated
royfrosty
You can RMA it with tech dynamic, BUT the keyboard has EOLed. Most probably they will replace you with another keyboard.
Another way if you really wanna test whether is it keyboard issues, you can always head down to SLS and get a cheap keyboard at $8.
