conradmichael
- Jul 4, 2017
Hi everyone, I'm having issues with consistent BSOD, crashing web browser pages, and programs that 'stopped working'
My Motherboard is: MSI H87-G43 Gaming
and Ram is: Corsair Vengeance 16GB
A friend told me later on that they were technically incompatible and offered some BIOS tweaks(Dram Timing, Advanced Dram Configuration, Dram Voltage, Dram Frequency) to which i applied.
However after the changed settings, i started to have the blue screens(Page fault in non paged area) and crashing programs,
I also stress tested with Prime95, and errors were always found between 1-2 hours or the program stopped working, I then attempted to revert the settings back to its Defaults, which were mainly all set to 'Auto'. But the issue still remained.
Before I was made aware of the incompatibility and did the BIOS changes, everything seemed to run fine for about 3.5 weeks, So were these problems I'm facing now inevitable because of the incompatibility or did we mess with the Bios settings poorly, and is there any way i can cleanly go back to its defaults.
i can post the value changes i made to the BIOS previously if it will help.
Thank you for any help.
-Conrad
-Conrad
