Help with my rig
D0tsss
i5 4570 + Msi B85g43
WD blue 1TB
gigabyte r9 280x
corsair tx650 modular
Corsair Carbide AIR 540
can help me add in 8gb ram , any cheap for bucks ssd 128gb
can list out the price for this build
Thks in advance
royfrosty
MSi B85m G43 + i5-4570 ~ $356
Kingston Value Ram 8gb 1600mhz ~ $93
WD Blue 1tb ~ $78
Silicon Power V60 120gb ~ $120
Gigabyte R9 28X OC 3gb ~ $445
Superflower HX600 Golden Green 600w 80+ Gold PSU ~ $129 (can get lower)
Corsair Carbide Air 540 Silver or Black ~ $155 (depends on how you bargain)
Total ~ $1376
Optional purchase:
Samsung ODD ~ $21
Windows 7 Home premium Oem 64bit ~ $115
Windows 8 Home premium Oem 64bit ~ $120
origamii
is Superflower HX600 Golden Green 600w 80+ Gold PSU brand good?
royfrosty
Yes it has made a lot OEM brands and also if you do your homework and research it only make good Gold and Platinum Range for other brands like
OCZ
Kingwin Platinum
Rosewill Platinum
NZXT Hale 92+ and 90+
D0tsss
Are there any diff between Plextor M5 Pro 128GB and Silicon Power V60 120gb?
D0tsss
btw those price u listed are lowest? Or can still get lower?
Can I play bf4 with high setting?
origamii
frosty for ssd i tried b4 samsung 840 120gb but never tried other what are the diff?
shadow84
r9 280x cfm can play ultra..... update the drivers to latest....
royfrosty
I saw someone saying his com hang/freeze when playing bf4 and his specs is abt the same as mine.
The dell 2340l u using issit good?
Hang or freeze is nothing to do with com specs if it is the latest. Its the game currently not stable for playing. Must wait for their patch release.
Yes I'm loving this monitor. Playing bf4 with clarity.
Jian19
I believe plextor m5p is 5 years warranty ~ Samsung 840 should be 3 ~
