help with new pc build
ddasuki
hi guys just wanna check is there anything more i can do to improve my build that i'm about to buy?i just need the tower itself as i am reusing my kb and mouse and speakers.planning to use benq xl2411t as my new monitor btw
mobo/cpu:asrock z87 killer/i5 4670k $501
rams:corsair vengeance pro 4gbx2 $125
gfx/psu combo:palit 760/tt se 630w $395
ssd:crucial m500 240gb $189
hdd:wd1tb blue $77
casing:ss ft02 $369
total:$1656
what do you guys think?budget is actually about 2.5k for monitor plus tower
shadow84
Where are you gonna get the XL2411T? XL2411 has been EOL le, and xtreme solutions is selling the XL2411Z at $599.
Can drop the vengeance pro to normal vengeance or KVR. Wun make your pc fly faster with the pros.
Can consider 280x as 760 will soon be not enough to maintain gd fps for upcoming games. If you are gonna break the combo, go get seasonic G650w or superflower HX600w psu.
Case is peronal preference, but imo, that 1 quite ex. You can get something like arc midi, air 540, 450d, 750d and have some allowance for other stuff.
ddasuki
oh yah the xl2411z...casing is personal..have been wanting that one quite badly..already using fractal design one and quite boring...and i've always preferred nvidia lols...think i'm gonna break the combo and get a better psu and downgrade to normal vengeance...is the amd one better performing?coz i'll just be playing mostly csgo haha...what oher adds can i add?
MoneyFace =p
CPU+MB: Intel Core i5-4670K + ASRock B85 Fatal1ty Killer @ $407
WC: Corsair Hydro H100i @ $155
RAM: G.Skill RipJaws-X DDR3-1866 CL10 8GB Dual Channel Kit [Red] @ $115
GPU: PowerColor R9-290 4GB PCS+ @ $618
SSD: Crucial M500 240GB @ $175 (t258jgn)
HDD: Western Digital Blue 1TB @ $72
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Super Flower Golden Green 600W [80 Plus Gold] @ $105
CASE: Corsair Obsidian 450D @ $165 (t258jgn)
Total: $1833
Optional:
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Buy others from Tradepac, #05-18.
Jian19
CS go ? :s22:
Casing can consider nzxt h440 @ $190
Sui ~
shadow84
If its jsut CS:GO, 760 would be more than good enough le. But if u r gonna play other high end fps games, then you may wanna consider 280x, 770 at least.
valkarian
Wow. Er let me add my two cents haha...
You're obviously looking to overclock the cpu, but I don't see a cpu cooler. Perhaps a cm hyper 212 for air or a liquid cooling system should be considered. Stock fan won't help you overclock your cpu.
Next, I understand case is a bit of a personal preference, but with such a system you might as well aim for a better gpu. Save a bit on the case and perhaps aim for a case and psu combo instead, and get a better gpu. 280x if you can find it, or any better green card. Anyhow, try to aim for gpu being one of the most focused items in your build.
If you're getting normal vengeance, consider the low profile if you getting air cooling.
Also, what os will you be using?
And Power is okay, but might wanna get a better one if you ever intend to get a future dual gpu.
Yeah. That's my two cents for now. From a newbie builder trying to help haha.
royfrosty
My recommendations
MSI Z87 G45 Gaming + i5-4670k ~ $499
Gskills Ripjaws 1866mhz 2x4gb kit Red ~ $115
WD Blue 1tb ~ $75
Crucial m500 240gb ~ $185
MSI r9 290 4gb Twin Frozr ~ $667
Seasonic G650 650w 80+ Gold Semi Modular ~ $135
Corsair Obsidian 450D ~ $169
Samsung ODD ~ $21
Corsair H100i CPU Cooler AIO ~ $147
Total ~ $2013. Buy at tradepac. DIY
MoneyFace =p
My recommendations
WD Blue 1tb ~ $75
Samsung ODD ~ $21
H100i can really go so low?
