Help with new rig build
Speckrt
Hie all,
Can anyone recommend me a good custom rig that I could use for watching shows, surfing net and photo editing. Looking to build with a budget of 1k minus monitor.
Thanks
royfrosty
Hie all,
Thanks
Do you use photoshop intensively? And is it an everyday thing you need to do. And do you wish to game?
Speckrt
No, not intensively. But probably every once or twice a week will use it, for leisure. Gaming wise not so much for now I guess.
royfrosty
Ok.
1k for an i5 rig
Asrock b75m dgs + i5 3350p ~ $ 271
Adata 1600mhz 8gb ~ $ 85
WD Blue 1tb ~ $ 78
Zotac gtx760 2gb + superflower hx500 500w gold efficiency ~ $ 399 (best bargain)
Sharkoon ms140 ~ $ 52
Windows 7 home premium 64bit ~ $ 115
Total $ 1000. Buy at tradepac diy. Gpu and psu get from best bargain. Install os using usb thumbdrive.
Speckrt
Ok.
1k for an i5 rig
WD Blue 1tb ~ $ 78
I plan to have two hard disk like a SSD to boot up and a secondary do hard drive for storage. Do you think is a good idea? Can also recommend me a good monitor say about 300 to 400.
royfrosty
If you need more space and ssd and don't intend to game then can get a lower tier GPU.
Asrock b75m dogs + i5-3350p ~ $271
Adata 1600mhz 8gb ~ $85
WD green 2tb ~ $110
Silicon power v60 120gb ~ $120
Gigabyte gtx650 2gb ~ $191
Cm 311 + fsp hexa 500w ~ $105
Windows 7 home premium OEM 64bit ~ $115
Total $997 buy at tradepac. Diy
Speckrt
WD green 2tb ~ $110
I just realised you added the OS inside too. Is there any parts that I can upgrade without the OS price?
royfrosty
Get a higher gpu gtx660 2gb
And
Corsair force ls 120gb
Should still be within your budget.
nippp0n
Why not change gpu to 7770 or 7750? IiRC, either AMD or nvidia works fine for Photoshop.
