Help with PC Build (1.5k Budget)
yongxuan96
Hello. I need some advice on building my first gaming/working PC. I know other people have already posted this topic a thousand times but i require the assistance.
Currently using a 3 years old AFTERSHOCK MX-15 Elite laptop.
Want to build a gaming PC cos i feel it's time for an upgrade and also, i'm sick of playing FPS in medium settings and low FPS on some games. Did some research and found out getting AMD is better then Intel if you are on a budget.
What i need from the PC is 1080 gaming, 4k is optional.
Able to play FPS, GTA V, FarCry etc in high settings.
Able to process photo and video editing.
Best if the parts can be upgraded for future.
BUDGET: 1.5K for pc only, already have monitor
Lastly, getting everything in one shop would be preferred as it easier for me, but im open to suggestions.
Again, thank you in advance and sorry i sound so noob.
ryuxdragonx
If you don't care for having the latest
Mobo+CPU – Gigabyte B450 AORUS M + 3600: $455
GPU – Gigabyte RTX 2060 6GB OC: $408
Memory – G-Skill Sniper X 3600mhz 16gb kit: $111
NVME M.2 – Crucial P5 512gb: $98
HDD Storage – WD Blue 2TB: $82
Case: Cooler Master MASTERBOX NR400 MATX: $78 (Personal preference)
PSU: Cooler Master MWE Gold 550w V2 FM: $102
Total: $1,334 (Based on Bizgram pricelist, lazy to check others)
You will still have $166 left for keyboard + mouse. You can change to a 2.5" SSD, a cheaper PSU to save some money as long as the PSU is from a good brand. You can also go for a cheaper mobo, depending on the features you need.
With this, you should be able to easily get 60-100fps on 1080p.
See if any senpais here have any comments on my recommendations.
Yongkit
I think the PSU should be more power at least 750w since TS mentioned wish to have parts for future upgrade.
Better PSU will ease for better GPU upgrade since you have recommended powerful CPU & Mobo.
Solojaywalker
everything's in one shop, can try PCthemes at sim lim.
they quite famous, also they can quote u a cpu build within minutes on the spot if u can tell them your kind of usage etc
just an alternative way, those kind bros below also offered informative advices but in case if you have encounter stock issues sourcing the parts components then can try the above suggestion.
goodchong
my recent setup around 1.6k
Ryzen 3600 with Asrock B450 Steel legend ~ 450
RTX 3070 ~ 850
G.SKILL Ripjaws 16 GB 3600mhz ~100
Samsung 860 Evo 500GB ~ 100
650W PSU ~ 60
Casing ~ 40
ryuxdragonx
Yeah can step up to 650 or 750 if it fits the budget
abstrax
I tik cant get any new GTX 1080 anymore now. Try carousell if u r still keen on it.
Rest of the parts....go to sls n buy....get a pricelist to compare n if u wan the shop to assemble, pay a small fee.
I dunno whether u can switch ur win10 from ur mx15 to ur new pc else nid get new win10 too
If u wan games to be high/extreme setting....try GTX 1080Ti
Oso can go for AMD GPU too...but make sure ur PSU got higher power
skrekro
5600x + b550m aorus elite 636
16gb 3200mhz corsair ram 120
500gb ssd crucial mx500 90
Palit 3070 gamingpro 818
650w seasoning psu 100
Tecware nexus m 50
1814
PCThemes. You can change the 5600x to 3700x and the gpu to whatever you want according to your budget but at the current moment there's nothing more worth at the cost due to current gen. That's the thing that sucks being stuck in between two gens. But I insist, up your budget to 1.8k and get the spec I provided. It's the latest and probably the best performance to price ratio especially at 1080p. Will be able to run 1080p max settings for much much longer
MoneyHoney
Tecware nexus m 50
1814
curious..why 3200mhz ram? isnt 3600mhz the most ideal ram?
also, 5600x + 3070 should be more than enough to max out 1440p right i.e. over 100fps on ultra settings in games? (i seen benchmark videos on youtube)
skrekro
yes but his budget is 1.5k so I spec the bare minimum to get the current gen stuff. 3200 vs 3600 not much difference except in price. Not worth it if you're overbudget
Not really but he is playing at 1080p so it doesn't matter. To answer your question, yes for esports titles. Aaa games such as control, horizon, valhalla, godfall all can't do 1440p at 100fps max settings
shadow84
If possible, please change that case. Airflow is crap on that case. At least Cooler Master NR400 at $89 or Fractal Design Focus G Mini at $79.
MoneyHoney
icic...yes it makes sense too after watching some benchmarks for 1440p...
ryry212
Need help as I am looking to build my first PC, but not sure where I should look to start reading up on it
tigerwoods
Tecware nexus m 50
1814
Does PCThemes have the stock in the first place?
skrekro
No idea. This is just a rough guide of what you can expect to get with the budget without taking stock into account. If you compromise and get last gen stuff like 3600 or 2070S, you're not maximizing your performance per dollar.
Bring this list around to other stores like tradepac, mediamart,viipc and compare. Happy hunting.
