Help with PC Problems
SongManKranji
High Honorary Member
Hi
Recently when PC booted up, it will suddenly shut down by itself, the screen turns blank but the PC power is still on.
I need to hard reboot the PC a few times and sometimes it allows me to surf net for awhile like now. Than screen will suddenly shut off by itself.
Any bros can help whats wrong, the HDD or the motherboard or PSU problem. Tks. :)
jtjt00
TS, can you list down the parts of your rig like those on the right --->?
XseanX
Hi
Can Try taking out the rams and run it individually, clear the cmos and reset the bios setting to default when you are on it...
If the above steps fail, try taking out any discrete graphic card and run via the integrated graphic if your processor have it...
