Help with psu choice
Pokerr
Hi Guys, would like to ask if I should get superflower leadex ii 650w or
Seasonic focus+ 650w for upgrade to prepare for the new rtx gpu.
Thanks in advance
watzup_ken
I feel both are good PSUs. My recommendation is to go for whichever is within your budget and warranty duration.
Elysium87
best is superflower, follow by seasonic. but both are the best out of others. just see your budget. i went with seasonic
Pokerr
thanks for the advice.. just got the assurance to get superflower, if get 550w enough for single gpu setup with perhaps rtx 2070
Kei_Li
Going is one thing, how many sdd/hdd u using, any optical drive, ram, etc etc... while 550w usually enough, can consider get 650w if price diff not much.
sunht
How is cooler master PSU? Saw its v series 850W 80+ gold is cheaper than other's 650W PSU.
Sent from OnePlus 5T using GAGT
watzup_ken
I've used Coolermaster's PSU long time back. It's OK, but the rig wasn't very power hungry. Coolermaster is not known for their PSU, so not many will recommend. After all, I don't think they make their own PSU so it's likely some OEM PSU that they slapped their brand on.
watzup_ken
See the price difference. With power requirements going up, will be safe to get 650W. I was using a Seasonic G550 and it works very well for me. I recently changed to a 750W after upgrading my graphic card.
