Help with random com hang
Kunkka
Com would freeze after a few hoursof on time. I will leave it there come back the screen with be unresponsive. Clock is still the correct time. Mouse can move around and click but nothing will happen. After awhile display with have no signal
Only way to use com again is to force restart with power button.
obichacha
Can share your pc specs?
tsteo77
Please list full pc spec and explain what you done before this happen.
shawntyq
Altho not enough info but One of the few things you can do first is
go cmd
-sfc /scannow
-chkdsk /r
or do a memtest
If all fail just reinstall windows again.
jasonwsc
Update BIOS, turn off overclock/XMP.
DDU and reinstall GPU driver.
Update Chipset driver.
CHKDISK or swap out SSD.
Check task manager and see if there is anything running in background. Scan with anti-virus.
If still cannot solve might be hardware issue alr. Culprit most likely either motherboard or SSD, but can also be GPU or CPU.
Kunkka
Ryzen 1700 at 3. 8 ghz but Task manager show is hovering at 3.7
Gigabyte Ax370 k7 on f24e bios
32 gb ram at 2666mhz cl 20
Evga 3070
850 w evga g2
Crucial mx 300 525gb varies around 40 to 50 gb free
Toshiba p300 3 tb
Reliability monitor last readable error is bluescreen code 7a with a bunch of parameters
First error was livekernelevent code 15e 2 weeks ago than the computer started hanging a few days after that.
I usually leave my com on all the time or in sleep. Cuz i know once restart might have this problem. I fix it previously in jan by switching on airplane mode. Didnt crash for weeks. Then i roll back windows but the problem came back in march
Kunkka
go cmd
-sfc /scannow
-chkdsk /r
or do a memtest
Tried running scan cannot complete
Soon after the windows disappear left this
jtjt00
Suspect your SSD or HDD is having issue. Do disconnect all secondary SSD/HDD, leaving only OS SSD and then run sfc /scannow.
wtfh4x
Yea sounds like your OS drive is dying already. I would run crystaldiskinfo, see if it's reporting any problems.
86technie
Evga 3070
850 w evga g2
Toshiba p300 3 tb
- Do a clean install of Windows and try again.
The PC is many years old suspect could be corrupted Windows.
- Download Crystaldisk check the SSD/HDD health.
https://crystalmark.info/en/download/#CrystalDiskInfo
Sometimes Windows can be slowed down by a faulty hard disk.
