Help with scanner problem
simple_n_eazi
Hi
I am currently using Fuji Xerox M205 f laser printer.
Recently, I tried to scan my documents and I noted all my scanned documents are entirely black. I suspect that the light bulb inside is faulty as I don't seem to see any light when scanning.
Can anyone teach me how to solve this problem? My warranty should be expired already.
Many Thanks!
Koenig168
If there is no light, then the bulb is dead. You can try replacing the bulb but I don't think it is easy to find the bulb for sale separately or disassemble to replace the bulb.
You can consider a standalone scanner which should be less than S$100.
simple_n_eazi
Anyone knows if Simlim square has such replacement part? I think is not easy to disassemble on my own. Probably need someone to help with that.
