Help with system build and cutting costs
born996
Hi im a first time builder wanting to purchase 2 sets of the same system config, i need help on cutting costs on the parts as well as which stores in SLS gives more discount if all bought at same shop.
My budget is around $1.2k~$1.4k, and i would like to be able to add more ram/SLI in future
As for my config, here goes:
CPU - Intel Core i5-4670K 3.4GHz Quad-Core Processor
Motherboard - Asus Z97-A ATX LGA1150 Motherboard
$561 Bundle @ TRADEPAC
CPU Cooler - Cooler Master HYPER 212X CPU COOLER
$55.20 @ LAZADA ($65 with 15% OFF)
Memory - Kingston HyperX Fury 16GB (2x8GB) DDR3 1866 CL10 1.5V
$91.40 @ LAZADA ($215 with 15% OFF and share cost with other system, ie each system gets 1 x 8GB stick)
Storage [SSD] - SAMSUNG 850 EVO 120GB SSD
$129 @ Cybermind + FREE 16GB SD card
Storage [HDD] - WD 1TB BLUE
$72 @ TRADEPAC
GPU - ASUS GTX960 4GB STRIX DDR5
$398 @ TRADEPAC
Case - Bitfenix Shadow
$58.70 @ LAZADA ($69 with 15% OFF)
(IF possible, able to buy cheap NZXT phantom white? its really nice)
Power Supply - Superflower Leadex Full Modular 80+ 550W Gold Power Supply Black
$109.70 @ LAZADA ($129 with 15% OFF)
OS - Windows 8.1 OEM
$125 @ Cybermind
These totals to $1599.93 which exceeds my budget without mentioning that i have not purchased any PCI-e wifi card or monitor. Need not purchase KB/Mouse.
Thanks!
royfrosty
If you really wanna cut cost then why still go for a z97 and unlocked cpu?
And why buy a asus 960?
born996
well, asus is known for their reliability right? and since im not getting i7, i would like to OC the CPU. as for 960, i would like to go for brands like MSI/GIGABYTE/ASUS
shadow84
$1.2k for both systems?? What is the purpose of the rigs?
U can reduce costs by doing the following:
Get i5-4460 and H81M mobo like MSI H81M E33 or ASrock H81M HDS. Since u r giving it 1 RAM stick, mobo with 2x ram slots is enough.
Dun need CPU cooler, stock intel cooler will do.
For rams, u might consider this: http://www.lazada.sg/hynix-4gb-1rx8-pc3l-12800u-ddr3-1600mhz-dimm-desktop-ram-531756.html?boost=1. Use BIG10 to get $10 off. Buy seperate to get the $10 off each but check on shipping.
U might wanna consider sapphire r9 280 instead.
shadow84
The chances of ASUS mobo dying on you are the same as for MSI/Gigabyte. Who knows, the moment u power on ur ASUS mobo, it might be DOA. Its all about luck. Paying more for 'marketed luck' is simply :s22::s22::s22:
Ark Law
$72 @ TRADEPAC
$398 @ TRADEPAC
$125 @ Cybermind
Thanks!
Want save cost still want to get 4670K?
Want save cost still want to get Asus mobo?
Want save cost still want to get Z97 class mobo?
Want save cost still want to get aftermarket cooler?
Want save cost still want to get kit RAM?
Want save cost still want to get Asus GPU?
Want save cost still want to get GTX960?
Want save cost still don't want to get win8.1 from G2A?
You tell me how you wanna save cost when you wanna splurge on all these stuff :s8:
trento
Ts, is it u want high end system with cost saving right? Rather than cost saving as yr main goal, correct?
orlengtao
penny wise, pound foolish... this quote is explains it all
avsquare
Harsh whacking but true :s13:
alienaire
if you do your research around here you'll know the 850 evo 250gb can be bought for 140 or slightly lesser. also, 400 for a 960? might as well got for a 970 for that price.
born996
SSD : in SLS?
GPU: i need the 4GB VRAM as the system will be used for rendering as well as gaming... right? or am i wrong
btw, anyone knows which shop in SLS sells Gigabyte GA-Z97X-SLI? i think its a cheaper alternative and still good but their pricelists dont seem to have..
royfrosty
It does not means that you spend on mobo means you are getting top notch quality and all.
There is no such thing as super ultra mantra mobo that will bound to have 0 defects.
Its rather a lucky or unlucky thing. Electronics quality components is a hit or a miss.
It does not mean that you spend less on mobo means its the worse quality among the rest of the top of the line mobo.
Go for ASRock h81m hds, Msi h81 e33, ASRock b85 pro 4, Msi b85m g43 ECO.
With value rams at $79/8gb stick. Doesnt mean it looks fancy means atas performance. When in reality it offers negligible performance.
SSD just buy transcend, plextor m6s, crucial bx100 ssd will do. You dont need top of the line ssd when it offers negligible ssd.
If you research enough you can buy a beefier graphics card than a gtx960. And asus 960 vs zotac 960 is not gonna give you high advantage.
Ark Law
hey i just wanna see which parts to cut so i can hit about 1.3k ma
Just change CPU & mobo can hit < $1.3k, and I haven't even got to the other components
CPU + MOBO: i5 4460 + MSI H81M-E35v2 - $308
CPU cooler: N/A (no OC)
$1599.93 - [($561 - $308) + $55] = $1292
localITguy
Suspended
SSD : in SLS?
want cheap. go asrock.:o
localITguy
Suspended
cut cost on the PSU its better :D
no just kidding
can cut cost on the processor and board
