Help!
xtNero
Hi guys, i've recently thought of getting myself a new rig and i was wondering if i should sell my GTX 760 and replace it for a r9 280x or keep it to sli. Please give me some suggestions, thanks!
xtNero
Im not exactly sure if it's capable of running Bf4 on 1080p at a constant 60fps.
Jian19
If u wan to max out @ 1080p then x280 will be a better card ~
Gtx760 with a few options turn down can play as well
xtNero
Can you guys recommend me a build with a budget of $1k excluding the gpu?
royfrosty
Msi b85m g43 + i5 - 4570 ~ $ 356
Gskills ripjaws 1600mhz 2x4gb kit ~ $ 110
WD blue 1tb ~ $ 78
Plextor m5p extreme 128gb ~ $ 159
Superflower hx600 600w 80 + gold efficiency ~ $ 109
Fractal design arc midi ~ $129
Total $941 Buy at tradepac. Diy. Ask tradepac to price match psu with mynextcom.
Better ram. Better ssd. Better chassis.
Jian19
Ur win7 is tie to ur mobo, unless u mean *ahem* version
Anyway even so u can reuse it as well, just call them and say ur motherboard up lorry and u change to another mobo, they will give u a new set of key..
xtNero
I meant to say that i have a genuine set of Windows 8 installed on my current computer and the windows 7 disk is just something i had from before with product key included of course.
Jian19
Can consider add a CPU cooler..
Xigamatek Gaia ~ $40
