Help!
xtNero
Is it normal for my cpu(i5 4670) to be running at an average of 50+ degrees on all 4 cores whilst running Dota 2?
*Using Stock Cooler
jiaweiii
*Using Stock Cooler
yes 50+ degrees very good already after hit 90 than not normal
xtNero
Also, is it wise to put a soundcard directly under a gpu? My headphones actually has a lingering buzz when it's quiet.
shadow84
If possible, put on top of it or as far frm it as possible (lowest pci-e slot)
AnTiLooP
Nothing wrong with your temps... and yeah I have a s blaster below my gpu too
xtNero
Do you notice any humming/buzzing sound when there isn't any sound output?
*Im using a Stx
xtNero
Are there any viable options other than to move the soundcard away from the gpu to reduce/remove the hiss?
