Help~
vinnyinny
My lap top is Aftershock XG15 V2
Running windows 10..
How do i find the camera driver? There's no "Imaging device" inside
cct75
You got download the Windows 10 driver package for your model from AS's Support page? I did not test the camera as I do not use but so far my older XG13v1 does not even seems need the drivers. It auto detects and installed from Windows 10. Perhaps I should check at Device Manger to see if any devices went MIA that was not registered properly.
vinnyinny
I know, i've it working in w7, but after going to w10 downloaded hotkey 8.....
pressing FN f10 wouldn't bring up the camera nor it is inside FN Esc :/
Anything_Whatever
I think you have to re-programme/re-assign the FN hotkey function for W10.
anyway, check out the youtube on how to repair or re-install the webcam driver...
https://www.youtube.com/watch?v=BT1Mz_TRXvQ
