help
deepblue_82
anyone using GTX 560TI with a ssd with about 20gb of space left
anyone is lagging?
seems i am lagging quite a bit.. anyone can help?
playing d3 ROS
will the 20gb of space cause the lag or the gtx?
jtjt00
The lag is more likely from your gtx560 ......
kandinsky
Quite easy to find out right, just clear more space on your ssd and you'll narrow it down straightaway...
superzheny
when on 4 player team and everyone casting spells on a horde, even my 970 will lag
deepblue_82
yup, fps plunges from the 200fps caps. However, cpu and gpu usage both not bottlenecking, so its likely the game engine not good. Reducing shadows help alot I notice
ok thanks i will try it out later..
