Help
slashiroth
Hi, I need some help here.
My PC parts are relatively new.
However, computer were crashing alot on me today so I decided to do a reset pc. When it was booting up again. It showed some error and could not boot into Windows.
So now I am trying to reinstall windows 10 using the windows 10 CD again but keep getting this error code 0x80070570 while installing windows again
Anyone faced such issue before knows how to get by it. I can't boot into Windows for anything now since my SSD is formatted while I tried to do the installation.
Im installing windows 10 via the CD
xonix
Retain only the essentials and try installing again ( although I suspect the problem is with your installation disc )
Essentials meaning:
CPU + MB + GPU + 1 stick of RAM + OS storage only
slashiroth
I'm running 2x8gb ram. So I tried removing the ram one by one to try the installation and I'm still stucked with the same error.
I do not have any other ram stick to try if it is the ram issue.
I kept only the essentials plus the mouse
Koenig168
It could be the CD is corrupted. Suggest you use Media Creation Tool to download Win 10 onto USB drive and try again.
tsteo77
Your lifespan of your mainboard battery flat ?
Yoir hdd have bad sector ?
Your problem is quite complicated, if I were you, I bring it to sls because they have the parts and knowledges.
slashiroth
Went to get the RAM checked at the distro and it was indeed faulty, so got it RMA.
Now managed to reinstall back Windows and system is up and running.
The ram is only less then 2 months old. What bad luck
SkyShroud
yes, sibe suay
ram got lifetime warranty, damn rare will be faulty
