High performance power cord
kandinsky
I guessed it, must be AV equipment lol.. must also find a $2K hdmi cable for your $2K GPU right 🤣
Koenig168
I got conned into paying a couple hundred bucks for a cable at SLS many years ago :s15: It was for a subwoofer which didn't need that kind of cable.
wwenze
If you use this power cord you will get better winrate and matchmaker
magix
No point getting this for PC. For audio device not too sure if this help.
tsteo77
Hi guys, look carefully and you will realise this hi end power cords that can be use for hi end computers and audio equipments and they don't have fuse. Anyway just spend about 10% of your pc on power cable will be enough. Mine only cost $5 from SLT few years ago as fuseless powercord were not popular. I brought more than i need as i think they will be no more stock once they are sold out. At the same time i also brought some fuless 2 ways power adapter from cybermind SLS.
They used to some sort of benchmarks for hifi equipments. I read it but don't understand, 18 yrs ago on hifi choice magazine. Anyway this cables does not make your pc go faster, it just de-restrict and bring out the best of your equipments.
wwenze
Safety notice: Fuseless power plugs are not allowed in British / Singapore countries. The exception is the 2-pin europlug connector which has a max current of 2.5A and can only be used with double-insulated equipment.
tsteo77
But i brought this power cords locally from SLT. Brought a monitor from us that came with fuseless power cord and i used to have a electrolux vacum cleaner that use 2 pins 15A power cord. Anyway i enjoy my computer so much i not going back...I'm a bad person. :rolleyes:
yusoffb01
using 15A (3600w) fuse for 100w device is pointless
Clearnfc
These aren't for computers. They are meant for audio equipment....Whether they do work and improve sound or not is another question.....
However, these aren't the "high performance" more of mid range. IF money is not an issue, you can get this. Btw Siltech is another brand that is ridiculously expensive.
https://www.analogueseduction.net/mains-cables/nordost-odin-2-mains-cable.html
Covert to SGD, its around $31,150.....you can get 1 for your PC and 1 for your monitor. There is also 5m one for your vacuum cleaner.
Btw, they also have HDMI, USB and network cables. I guess this is what they meant by sky is the limit...
https://www.analogueseduction.net/usb-cables-usb-components/nordost-valhalla-2-usb-cable.html
$~6K for USB Cable
https://www.analogueseduction.net/e...cables/nordost-heimdall-2-ethernet-cable.html
$1.3K for ethernet cble.
