High quality VGA Cable
Hi guys,
Where can I find high quality 3m vga cable?
I was looking around at sls, they only sell those non-branded vga cable.
I bought one but my monitor graphic becomes blur when using this cable.
Hi guys,
Your BLUR means what?
You running VGA on what Resolution?
On your MONITOR native resolution boh?
wwenze
Once I bought a thick VGA cable from LHS... Also blur. And LHS is reputable shop wor as many can testify. In the end use back the one bundled from monitor.
sth like double image, the wordings like got trail.
i've got 2 monitors connected to 1 gpu. 1 is 1440p 144hz, the one got problem is 1040p 60hz connected with vga cable. both set at native resolutions.
Elijahonli
erh its recommended to use dvi/hdmi cable for 1080p.... vga not enough bandwidth
kandinsky
Think this is referred to as ghosting.
If the cable is new, may not be cable issue. Got update display drivers?
Try experimenting with different refresh rates...
List GPU and monitor models?
yusoffb01
Set at 1080p instead of 1040p sure won't be blur
actually before i got my 144hz monitor, i was using original vga cable from the monitor itself and no problem at all.
But now i am dual monitoring and the length of vga cable not long enough so I had to buy a 3m non-branded cable.
so i guess it should be the cable problem?
Test if same problem persist on your original short VGA cable.
