High Temperature on rig
geniusboi
Unable to self diagnosed the high temperature. Decided to bring the system down to sls for checking next week. Maybe change my psu and add a new cooling system while I am at it.
kandinsky
Update:
I have just removed the stock fan / heat sink and removed most of the dust on it. Use a camera blower and a very tiny paintbrush but still cannot totally remove them
Reapply thermal paste. Use nail polish remover (don't know if i did right, lol) to remove the old ones. Then apply a generous amount of Arctic MX-4. About a rice grain onto the centre of the processor. Then painstakingly reattached back the fan (quite difficult actually).
Fix back everything but the temperature still the same.
If the temps only surged after you upgraded the GPU (Before that was fine for the past 5-6 years?) then it's possible that the GPU is creating new heat that your chassis fans can't handle...
In the meantime, either swap your GPU back out or try turning HyperThreading off to see if it helps.
Can also take a pic of the interior, can take a look at the airflow.
geniusboi
If the temps only surged after you upgraded the GPU (Before that was fine for the past 5-6 years?) then the GPU is the likely culprit...
I very long never check temperature already. So not sure if it is because of the gpu. Old one spoilt, thats why bought new one to replace. Just removed Intel Speedstep. Slighly better now. Idle at 55-64.
Does these photos shows my airflow?
bemylove
maybe try a different sensor program like hwinfo.
because all your other temps so high. could be bug of hwmonitor with your older hardware.
this kind of temps run a few minutes youtube 4k video may bsod. or even run some cinebench will shutdown.
kandinsky
I see. 55-64 is still damn high, lol. The pics help, but only can see two fans. Is the top one intake, rear on exhaust? You mentioned your case has four fans? What's the actual config?
4 fans. One top one bottom one front one back.
Personally I'm not very exp with airflow, will let the more exp bros comment on this.
FroztSpectre
Back and Top fan looks both exhaust to me.
Generally:
kandinsky
Generally:
Ah, yes. Thanks for clarifying. I was wondering that cos TS first post said "Currently have like 2 stock fans that comes with my casing. ". So I thought 2 fans only, lol. Later then saw the other comment.
geniusboi
So is correct right? My 2 other fan is at the harddisk area at the front and the psu area at the bottom. At the front fan X 1 and Bottom fan there got 1.
geniusboi
Haha tried all the software already. HWinfo same temp.
