gregory_choo
- Nov 7, 2007
Do you know where can I get the H7G3 firmwave with Google play?
lost touch with hi-media.
However, I think you can install google play without new firmware.
just root your box, then run google installer to install playstore.
if not, use the old way to install - root, copy a few files to system folder, change property to rw-r-r, reboot.
for old way's detailed procedure, search for my old message 5-6 years ago.
suggest to use google installer, it should be easier.
BTW, the easier method is to buy a new box, you can now get one with better chipset 2g/16b for less than $30.
