home karaoke
kurtgoh
Well if you using android box, you can make use of those free karaoke apps in the play store. Its one alternative for chinese songs but they do have ads thou. The good thing is its free.
could you share the names of these apps?
BeiBei90
Anyone tried Popsical karaoke system? Any comments to share? Also, can sound bar be used for karaoke? According to sales person is cannot support the higher pitch sound.
Thanks!
Aditshar
Popsical is subscription based karaoke system. if you are going to use it often then it should be good.
There are soundbars with mic input that can be use for karaoke. But most soundbars dont have the mic input for karaoke. Depends on your setup and how you gg to use it.
Thanks!
keewee0415
Thanks!
My wife's using it. Pretty decent and up-to-date library of songs in many languages with original MVs.
Speakers provided can be improved though as it sounds a bit flat compared to the 5.1 Home Theatre system in the same room. However, the speakers does provide settings for reverb and pitching, so the living room does resemble a KTV suite to some extent.
Hope this helps.
ksapple
Just order a ktv song selection machine, will review it once arrive hahaha
kensou
im using unblock ubox, they have internal ktv apps... the download speed is not bad, new songs also have, but i didnt use much only sing a few chinese songs.
ksapple
How much is the shipping?
The shipping is 100 for 1 cbm, buy at least 10 item then worth it.
I bot a few other thing like table and carpet and a few useless thing hahahahah
ksapple
Wooot lao liao lai liao
Sent from Sony G8142 using GAGT
ksapple
Can share how u connect ur mic?
Reference to my last 2 pics
Wireless mic receiver(Black thingy) to Karaoke Mixer Mic input 1 (Silver thingy)
Karaoke Machine Audio Out using AV cable(Red/White) to Karaoke Mixer Audio Input
Karaoke Mixer Audio Output using AV cable(Red/White) to ur speaker or receiver.
