home karaoke
kendrick272
hey guys! the popsical remix, can use rca to hdmi convertor? my soundbar dont have aux/rca input.
I called the hot-line and they say the chances is 50 - 50.
jchoong
I bought a analog to digital converter (rca to toslink) but have not used it on my Remix yet - as I am still using my old sound system instead of the new soundbar. I think it should work, but not sure of the quality.
angy
Hi guys,
Could someone share with me, what is an portable, good and easy to install karaoke system where I can bring to friend's place and sing song?
If you suggest Youtube based solution, what are the portable hardware that i will need to set it up?
koolaid
for those of u who can sing very well, when singing duets, how do you usualy sing in harmony? any tips? i wanna learn but it seems to quite hard. :(
even with training video likes this, i still find it very difficult to sing the harmony part... :(
at the 5:24 part...
LeeSlayer
Suspended
Hi, you can consider the Karaoke Starter Pack of A.C. Ryan ($499.00) and it consist of MOMENT GEN 2 speaker, Subwoofer and 2 wireless microphones. :)
chesterchen
Hi there,
I am interested in purchasing the Popsical Remix (or another other brand/model that can fit my existing sound system).
I currently had a Sonos Playbar (https://www.sonos.com/en/shop/playbar.html) linked to my TV.
Would Popsical work with my set up so that sound could come out of my Sonos Playbar while the display appeared on my TV?
The Sonos Playbar only has an optical in from the TV.
Regards,
Chester
jchoong
Popsical Remix has no optical out but has a red/white audio RCA. You can buy a RCA to optical adapter to connect to your sound bar; I bought one from AliExpress but have not used it yet, so dont know the quality of the analog-digital conversion.
msaz
for pc just use smule and can use the onboard mic input. smule advantage is can sing together with kakis online. smule collection of songs is very decent for its price and you can still use same account for android or ios.
do not subscribe via ios . you will not be able to use on pc or android although same subscription pricing
runforyourlife
Moderator
Moderator
I saw teoheng got bundle with popsical... anyone has that? Is that good?
Thinking if need sound proof windows not...
moon04
one question about popsical remix. If hdmi goes to TV and aux goes to sound system or a soundbar. does it mean the music will not be able to be played through the sound system or soundbar at the same time as our voice. Because from what I see this config plays music out of the tv 's own speakers...and our voice thru whatever we connect the aux to.
jchoong
If you lower the volume of the TV, you will hear the karaoke backing music coming out from the sound bar too.
runforyourlife
Moderator
Moderator
Not really. since he wants a simple system to plug to his tv, just get a karaoke soundbar, fits his budget, and almost literally plug and play. You can do it yourself.
Then neighbours will have a hard time le
deadrick
lots of oldies even hokkien hahaha with their weird mtv hahah.
Plug and play only
Hey, can ask the karaoke box from taobao,
any auto update of songs?
is the song list complete for most chinese songs?
mainly singing taiwan and china songs only..
