Home theatre system
GMThans
Looking to set up a good home theatre system. Anyone can recommend a good brand/model for speakers, av system etc? Some brands I heard are Bose, Yamaha, klipsch, onkyo. Any kind advice appreciated! Thanks :)
Feel free to share your own setup too! :p
bo liao
deadrick
Better to have a good 2 front speakers than a normal 5.1 speakers. Learn my lesson years ago buying those complete set in courts. Turn out a $200 pioneer speakers sounds so much better than the given onkyo surround speakers.
bo liao
Advice i dun dare to say, sharing some views only.
One person's good could be another's lousy due to different expectation.
Most brand you listed have their decent series.
For bose wise, no comments...
*Take notes on receiver offering diff "Sound Format", or which can last you longer?(Mastering/Encoding of movie sound to give u the best experience).
Internal feature are also a plus point, such as air-play, wifi-link up etc.
*Power wise average actually is enough, unless you have the best possible neighbour beside you / on top & bottom of you.
*Subwoofer is very crucial.That is a factor that really make one's system stand out. (If u happen to listen b4 many diff set-ups, you may notice some bass are deeper then the other; some can be deep but cannot loud.Some loud but not deep bass. Series of trade-offs unless one willing to spent.)
*Mains spk are all the gun sound/explosion etc, Cte spk are for dialogs.
*Projector, i use a 3500 lumen LED (i believe is fake numbers lah).
Day time see show have to pull all curtains...Screen is also important.
*TV- Plasma i still feel picture is better but heavy & hot. LED tv pic quality still can..
*Room Treatment; Cancellation & Boundary effect & Bass trap, do read up.
Window glass reflect sound are also headache for a discerning listener
HT is a series of compromise.
Unless you can have a very good positionings of spks, everything set-up according to your preference.
What to recommend, i already lost touch & not updated. However, budget around $3k/- can get quite ok stuffs already.
*Amp,spks & 1 sub.
Bout $5k/- can be quite decent liao.
The more $ in more powderful lor...:s13:
GMThans
No budget, no details ???
Havent thought of a budget yet. Just looking for a good system for a small/med room. say 4m by 5m. If you really need to see a figure for a gauge. Maybe $5k +- $2k.
Thanks @bo liao for sharing :)
For now, speakers thinking of the klipsch premier series/wharfedale/dali/(polk and fluance havent listened to them yet)
AVR I'm probably looking at Denon/Marantz
kerrying
5k seems doable, assuming the budget covers display (tv) as well. Speakers are by far one of the most important and personal components in a ht setup, and this requires auditions. The speakers only need to sound good to you, you have to like the sounds you get out of them, so you probably need to do some checking around. Some of the really boutique brands have big price tags to them, so go wild and check them out.
Do you intend to listen to music on the same ht setup? Or you prefer dedicated stereo music playback? If you are really particular about this, you will probably want a dedicated stereo system purely for music playback, since preference for ht surround sound is often quite different from preference for stereo music playback.
Denon/Marantz they are now all one big family now, and they have aloooot of ranges, you are going to have headache picking one out, have fun. For receiver, probably can consider Yamaha and Onkyo?
bo liao
What "kerrying" said...
*To kaypoh abit..
TV 50" bout $1k/- [i may be out as long no go see pricing]
(Dun say 50" Akira that is sold at Giant Supermarket), above that are mostly $2k/- & up..
Projector- Use b4 epson @ bout $2k/-, now use some MIC @ bout $1k/- also can use.
Screen- Got many types, some will give better results/sharpness of pic.
I use hdb wall cos no $.
If 4 rm hdb (assuming is the average layout), its very hard to get 100" projection onto screen/wall etc due to the width of living room.
Maybe also have to take into consideration many ppl wanted TV console that comes with a full ceiling height wall feature.
*This type of installation, many fix a 50" tv on wall feature..then when wan see movie, a screen come down; be it motorize or not.
5Rm hdb can net u bigger projection of image as bigger living room mah..projector can put more behind.
*If listen music, thiel + krell with exposure pre-amp combo not bad..
Hope it helps a bit.
More gurus here will chime in de.
nomoney25
Not sure your $5k +- $2k included tv.
U can consider bookshelf speakers from B&W . Monitor audio or KEF. I got MA floor standing and centre speaker from monitor audio for about $2k.
Got a decent onkyo AVR with audysey xt32 calibration for $1.5k brand new that time. As I m more to 95% on movies. Got a rythmik sub woofer from econAV at adelphi for $1.7k.
Lastly the $$$ go for a decent rear or side surround speaker plus cable..should be around $6k . Initially I only set around $3k to build my home HT. After a few auditions and listening. I only like the sound and feel after I increased my budget to $6k.
fastcar
Bro nomoney,
Did you DIY and mix and match, or went to a particular shop and get everything from there?
sensesignite
Actually really depends on your budget and expectation.
I am just using basic one like Boston Acoustic Soundware 5.1 and Pioneer VSX S500 with a LED TV. Got it at adephi.
Really grateful to my friend who discouraged me to get those 1 set system from superstores.
I am really enjoying my show and music now.
Only thing is a bigger screen will be better. Maybe will go for projector the next time.
Play game and watch soccer on 80inch ....haha.
Do go to Adephi or Liang Court ( that is 1 shop there ) to hear the sound system.
Happy Shopping! Enjoy!
nomoney25
Bro nomoney,
Get my setup from 3 different shops. AVR from a basement shop. 5 speakers from monitor audio and a rythmik subwoorfer from econAV. All shops r located at adelphi.
fastcar
Bro nomoney, i took your advise n bought a 75X85c too. Now left with a budget of about 3-4k for HT/audio. Any configuratios u recommend? I am a casual user..Movies, music...etc..not a hardcore enthusiast.
thanks
TechVodoo
do u think its a good idea to get projector for movie playing?
gigigigi
depends on your budget and situation. objectively speaking is more troublesome but it is the most ffective solution for large size screen.100 inch and up...
sadboy
Recently Courts has been dumping Marantz / Denon / Boston Speaker cheap.
It really depends how much you wanna spend on Home Theatre.
Can be as cheap as $499 (Network Amp + Speaker 5.1)
86technie
Careful with cheap amps, some maybe very old model
or even display set.
So take precaution, I previously brought a $899 Onkyo
set but the model I didn't realize was actually two years old.
