Honda Fit/Jazz Part 2
andyhtc
Suspended
Hi bro
Like to check for FIT Hybrid GP5
Would like to ask is it normal to have(i would not say is jerk) but something like running with lower gear kinda of feeling when sometimes change to different mode of drive especially when engine drive kick in around 40km/h.
After it pass this speed accelerate higher i dont have this feeling any more.
It is always during the start part when change over to different mode.
Is it something wrong with my transmission or oil whatever.
Is it normal in this case?
Mileage is around 37,000
Appreciated!
If you have changed your transmission oil at 30k km, then it is just a normal slow gear change at 40 km/hr. The next gear changes are around 60 km/hr and 80 km/hr.
irelkZ
Thanks andyHTC
I usually drove with ECON mode off. Still have this feel. Sorry cant really describe how it is but is just like during the days when i drove in manual car with lower gear then the engine rev for a short while.
Usually this happen is when EV mode change to engine mode when step on gas.
Even i tried both ECON on and ECON off also feel this way.
So wonder maybe some FIT Hybrid bros here have the same feel as me or it is only my car issue.
Haiz
Try the non-Econ mode for faster gear change:
Throttle Response – When the Econ button is activated, the throttle slows down at the rate that your vehicle increases in speed, which saves on fuel consumption. For better performance, the speed remains unaffected at very slow or very high speeds.
https://www.tri-statehondadealers.com/when-to-use-honda-econ-button/
oceanicmanta
Thanks andyHTC
Haiz
mine kinda have this feeling too ... noticed it usually happens at low speed (like inside a carpark) and as if accelerator is pressed too lightly to trigger the gear change
irelkZ
Yayaya usually at carpark
So you have this feeling too
Normal?
I am not alone LOL
swassi
Bro, don't mind me asking, can PM me which PI dealer u got ur ride from? newbie here and can't pm haha!
Yah, they damn one kind one.
Oth, I can understand why they like that. Properly mounted Mugen bodykit need to drill holes to bolt on mah.
Plus, KM ownself got sell, of course they try to protect their own biz. So a lot of things if you do outside will void warranty.
In the end, 1 of the reasons I didnt buy from KM.
Lolicious
Thanks andyHTC
Haiz
DCT GB are like that. Don't worry too much
Sent from Xiaomi MI 9T PRO using GAGT
fake_oranges
myviowner
myviowner
is this legal to change to white light? haha..
Anything that is not stock is not "legal". Having said that, many still goes ahead and when time for LTA inspection, just need to replace it to stock. Else will fail the inspection.
Since your ride is a 2019, means you have another 2 years to go before the very first LTA inspection.
duorachai
Guys, does honda fit 2019 gk3 has clock spring? I am looking to install steering remote. Currently my steering wheel does not have any remote. Was wondering if the car has clock spring and can support steering remote installation. Noob here. Hehehe.
