Honor Magic V3
cth
maybe email their support, give them ur imei, they should be able to push the update to u..
I see. So it's not "built-in" lah. I guess will just wait for the update. Now everyone getting their set, so quite reasonable to expect "traffic jam". :ROFLMAO:
cth
New to My Honor. Seems like when you change different countries you get different experience. Any issue if we leave it to "Malaysia"? Cos the "Global" one very bare.
thewiseone
Hardware for this phone is top notch... Just the sw I feel isn't as polished as Google pixel. Eg: only fingerprint unlock will bring u straight to home screen, not face unlock. Still need to swipe up after face recognition. No single swipe anywhere at home screen to pull down notifications shade. Will probably takes some getting used to but this is so light and thin it doesn't feel much different folded compared to my pixel 7 pro!
Justbear
cth
You can swipe from top-left down to get the notification isn't it? If you swipe from top-right down, then you get the Control Center.
thewiseone
Yes but for others like pixel, u don't need to reach to the top left to swipe down for notifications. U can literally swipe down anywhere on homescreen to do that.
winningeleven
Last time huawei is able to do that. After that left is notification and right is control. Actually I prefer the old way. But then when I tried the display set of magic v3 . I always can feel the OS is like huawei. Give a double knock on the screen is screenshot also
elementz
You can customize them in their respective settings, to get those 2 features you mentioned.
eddy0505
Agree, software they are catching up but need more work. Actually you can swipe anywhere, just go settings >home screen settings> disable honor search. There you go, it's an android feature, not a pixel only feature lol.
You can also alter facial recognition settings, you can directly unlock without swiping, also an android feature. Play with the settings a bit, might not be as simplistic as Pixel as there's skinning.
The Pixel experience sometimes I feel a bit overrated.
