doki81
- Jun 11, 2010
go in security ..i think the play system update is there.Where to update? I in play store tap setting n update but nothing
About phone---> google play system updateWhere to update? I in play store tap setting n update but nothing
i wanted to give to my niece.. i using samsuck ultra now.. keep on disconnect with honor.. have to stick to samsuck fold 4 for now with watchWatch is trash lah.. u want to sell people don't want to buy
I tried, same.Dunno whether toggle on the keyboard edge swipe protection would help.
AMK Hub level 2. UV glue type but I'm looking for privacy type.anyone knows any local shop got sell tempered glass for the front screen?
And also why need to unfold the phone for optimal charging??![]()
Should be larger surface and thinner to disperse heat ba.. There say optimal ma, not say faster..i was told this before for the v2 also ... i can't understand the logic behind it ....
electricity cant flow around the bend to reach the other battery ?
To disperse the heat. Both side also got battery and "kiap" together, more hot.i was told this before for the v2 also ... i can't understand the logic behind it ....
That is my fav phone tooOne ability which I missed after my Huawei Mate 20X rip is...
Set the alarm clock, switch off the phone (Power Off)..
Next morning, the phone will turn on itself when the alarm is sounding off..
Honor used to be under Huawei and of course this gene is brought to Honor!![]()
Oppo watch 3 pro paired with HeyTap health.For this using watch with this phone, what watch are u guys using?
Thank.2 ways you can try.
1) Developer options > Stay awake(Keep screen on when charging)
2) Settings > Home Screen & Style > Standby > Turn it on > Display mode set to "Always on display when charging"
Using with my garmin . But yesterday night it drain 15% just after 1 night when I was sleeping. I turn off run on the background to monitor againFor this using watch with this phone, what watch are u guys using?
Thank you!【淘宝】限时淘金币抵2.9元 http://e.tb.cn/h.gJFpgtxLOezPMPT?tk=48Hf37sBkw5 MF6563 「适用于荣耀magicV3手机壳原装正品中轴磁吸饺链支架保护套V3原厂折叠屏中轴全包磁吸铰链超薄防摔皮革保护壳」
点击链接直接打开 或者 淘宝搜索直接打开
Looks similar...
