Honor Magic V3
NeonX
So for transport (tapping bus and/or mrt), just need to unlock phone to home screen then can tap le? No need to open wallet?
yes no need to open wallet. If you enable the transit option, you don't even need to unlock, just screen on can liao i think
kaiser_11
I think the setting you shud fiddle with is under settings > battery optimization. Try and let us know if this fixes the issue. Coz I personally have no issues with any killing of apps/notification as long as I mess with the autolaunch and battery optimization setting for some tricky apps.
Hi!
I have set the two apps as Not Allowed under battery optimization. Still the same. :(
tellim
Do u guys turn on NFC the whole day? Cos if I want gpay or transport card to work without unlock, it's not possible unless I set NFC on the whole time
NeonX
I do, not as if nfc eat battery
Ray1976
oh well still the same. it shows the notification on the lock screen just that it doesn't vibrate.
Sounded to me like you have enabled Gentle notification which explains why there is no vibration but it still appears on lock screen. Make sure to uncheck that option and leave the allow notification intact.
yhw22
Can the Huawei Health app also sync MPVA/sleeping points to Healthy 365?
If you link with a device. I forgotten without device can sync MPVA or not. But sleep confirm can't unless link with device.
Amuroraysg
just wondering can i switch swipe down right to left? i want to use my right hand to swipe down.. for notification but hard to reach to the left side.. i don't mind the control center on the left since i seldom need to access it.
yhw22
SimplyGo somehow has no notification for mine too. I remember getting a notification then no more.
NeonX
You can swipe left right on the notification/
kaiser_11
ur talking about only vibration now or still no notification from simplygo?
My bad. I wasn't clear.
- MyTransport app: Have notification but on the screen. phone does not vibrate
- SimplyGo: No notification at all. phone does not vibrate
I have gone through all sort of settings and still don't work. Not sure the issue. It is fine I think might just be some bug. Hopefully an update on the OS or the apps can help solve the issue.
Thank you!
jazz6263
Hi,
I am thinking of getting the magic V3. Does it work with banking apps? When they ask for fingerprint, we just put our fingerprint on the side is it?
Regards,
