Honor Note 10 (6.95 inch AMOLED)
zortini77
finally got mine... realised the width is slightly slimmer than my mi max2.. hmmmmm...
Does any has yellow tint? its like the default display is tilted towards yellow.. i need to choose vivid and cold inorder to knock off the yellow tint.. but sometimes it comes back.. any advice?
i have not try putting my sim card yet...
thanks all.
monsterz
Just got my too but the video recording seem quite bad on FHD. The video i took when walking will have a second of blur on off...its like trying to focus on the view.:(
Not sure its my set faulty or its just the video recording suck.:s22:
Can anyone try?
Tks
Nakedtoes
Can anyone try?
Tks
Huawei video recording is always sucks one.. It's normal.
Gametaku
thanks all.
AMOLED consume more battery when the screen is pure white. The yellow tint helps with the battery life. You can set it to white but i will just leave it as it is.
zortini77
Hi Gametaku,
you mean the yellow tint is normal? your phone got it? i find it painful looking at it... i need put it under vivid and cold in order to minimise the yellow tint.
zortini77
Hi all,
apologies for all the simple questions, as im not familiar in buying a china set. my normal apps like youtube and facebook keep crashing after using awhile?
any remedies?
thanks you.
Gametaku
Hi Gametaku,
Yes, default setting has yellow tint (more toward warm setting). You can adjust the color to more whitish using the color scale.
boaboy
Saw on carousell someone selling hk set with global rom $740 for 6gb/128gb while china set $680. Hk set with global rom seems worth?
kyleongwl
Not sure if its to buy this Honor Note 10 or the honor play or mi max 3...
boaboy
Looking to buy 1 set of used note 10. If anyone letting go pls contact me @ 91879585, cheers
Nevereatrice
There's no global rom for it yet. Likely is just another install Google store delete away the Chinese apps but still Chinese rom.
Don't be misinformed
boaboy
This is one of my worry too. Difference is $100. I check with seller he v confident telling me confirm is global rom
kennyboy
Told him to give me a picture of the packaging, he tiam tiam liao. No need to open box also can see the packaging for global and China set will be different.
SibehHL
If considering Mi Max 3 then maybe should also consider the upcoming release of Honor 8X Max with a 7.15" screen... sale price should be slightly above the MM3
boaboy
Lucky got u to qn him oso. Seems like getting china set from him still worth but hk set really is a qn mark
