davidktw
- Apr 15, 2010
Is there any reason why it doesn't work ?
Document doc1 = Jsoup.connect(exportmonitoring).userAgent(USER_AGENT).timeout(0).post();
Hi there,
the websites takes like 5 secs to load everythings,how to set a delay or something to make it load fully first
Do you mean it takes 5s to get back a Document object ? If so, it's the network that is slow or perhaps the web server where "exportmonitoring" is referring to is that slow ?
What delay do you want ? If you get back a Document object, it has been fully retrieved.
i mean there is still a cut some where,when i print out the document.
Provide me the URL you are referring to, I will use jsoup and retrieve it and take a look what you are talking about.
internal by vpn only.
the cut is still by <td....... only 50 out of 100 rows retrieves.
but document takes 10sec to load on browser itself.
java - Trusting all certificates using HttpClient over HTTPS - Stack Overflow
Can i use this for basic http authentication?
//enable http entity
import org.apache.http.HttpEntity;
import org.apache.http.auth.AuthScope;
import org.apache.http.auth.UsernamePasswordCredentials;
import org.apache.http.client.CredentialsProvider;
import org.apache.http.client.HttpClient;
import org.apache.http.client.methods.CloseableHttpResponse;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.BasicCredentialsProvider;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.impl.client.HttpClients;
import org.apache.http.impl.conn.SingleClientConnManager;
import org.apache.http.util.EntityUtils;
import org.apache.http.conn.ClientConnectionManager;
import org.apache.http.conn.HttpClientConnectionManager;
import org.apache.http.conn.scheme.Scheme;
import org.apache.http.conn.scheme.SchemeRegistry;
import org.apache.http.conn.ssl.SSLSocketFactory;
import java.io.InputStream;
//create inputstream
import java.io.InputStreamReader;
import java.io.Reader;
import java.net.URL;
import java.net.URLConnection;
//disable authentication
import javax.net.ssl.HostnameVerifier;
import javax.net.ssl.HttpsURLConnection;
import javax.net.ssl.KeyManager;
import javax.net.ssl.KeyManagerFactory;
import javax.net.ssl.SSLContext;
import javax.net.ssl.SSLSession;
import javax.net.ssl.TrustManager;
import javax.net.ssl.TrustManagerFactory;
import javax.net.ssl.X509TrustManager;
import java.security.KeyStore;
import java.security.SecureRandom;
import java.security.cert.X509Certificate;
public class login{
public static void main(String[] args) throws Exception{
SSLContext sslContext = SSLContext.getInstance("SSL");
// set up a TrustManager that trusts everything
sslContext.init(null, new TrustManager[] { new X509TrustManager() {
public X509Certificate[] getAcceptedIssuers() {
System.out.println("getAcceptedIssuers =============");
return null;
public void checkClientTrusted(X509Certificate[] certs,
String authType) {
System.out.println("checkClientTrusted =============");
public void checkServerTrusted(X509Certificate[] certs,
String authType) {
System.out.println("checkServerTrusted =============");
} }, new SecureRandom());
SSLSocketFactory sf = new SSLSocketFactory(sslContext);
Scheme httpsScheme = new Scheme("https", 443, sf);
SchemeRegistry schemeRegistry = new SchemeRegistry();
schemeRegistry.register(httpsScheme);
CredentialsProvider credsProvider = new BasicCredentialsProvider();
credsProvider.setCredentials(
new AuthScope("localhost", 443),
new UsernamePasswordCredentials(args[0], args[1]));
// apache HttpClient version >4.2 should use BasicClientConnectionManager
SingleClientConnManager cm = new SingleClientConnManager(schemeRegistry);
DefaultHttpClient httpclient = new DefaultHttpClient(cm);
httpclient.setCredentialsProvider(credsProvider);
try {
HttpGet httpget = new HttpGet("https://mycompanysites.com");
System.out.println("executing request" + httpget.getRequestLine());
CloseableHttpResponse response = httpclient.execute(httpget);
try {
HttpEntity entity = response.getEntity();
System.out.println("----------------------------------------");
System.out.println(response.getStatusLine());
if (entity != null) {
System.out.println("Response content length: " + entity.getContentLength());
EntityUtils.consume(entity);
} finally {
response.close();
} finally {
httpclient.close();
Code://enable http entity import org.apache.http.HttpEntity; import org.apache.http.auth.AuthScope; import org.apache.http.auth.UsernamePasswordCredentials; import org.apache.http.client.CredentialsProvider; import org.apache.http.client.HttpClient; import org.apache.http.client.methods.CloseableHttpResponse; import org.apache.http.client.methods.HttpGet; import org.apache.http.impl.client.BasicCredentialsProvider; import org.apache.http.impl.client.CloseableHttpClient; import org.apache.http.impl.client.DefaultHttpClient; import org.apache.http.impl.client.HttpClients; import org.apache.http.impl.conn.SingleClientConnManager; import org.apache.http.util.EntityUtils; import org.apache.http.conn.ClientConnectionManager; import org.apache.http.conn.HttpClientConnectionManager; import org.apache.http.conn.scheme.Scheme; import org.apache.http.conn.scheme.SchemeRegistry; import org.apache.http.conn.ssl.SSLSocketFactory; import java.io.InputStream; //create inputstream import java.io.InputStreamReader; import java.io.Reader; import java.net.URL; import java.net.URLConnection; //disable authentication import javax.net.ssl.HostnameVerifier; import javax.net.ssl.HttpsURLConnection; import javax.net.ssl.KeyManager; import javax.net.ssl.KeyManagerFactory; import javax.net.ssl.SSLContext; import javax.net.ssl.SSLSession; import javax.net.ssl.TrustManager; import javax.net.ssl.TrustManagerFactory; import javax.net.ssl.X509TrustManager; import java.security.KeyStore; import java.security.SecureRandom; import java.security.cert.X509Certificate; public class login{ public static void main(String[] args) throws Exception{ SSLContext sslContext = SSLContext.getInstance("SSL"); // set up a TrustManager that trusts everything sslContext.init(null, new TrustManager[] { new X509TrustManager() { public X509Certificate[] getAcceptedIssuers() { System.out.println("getAcceptedIssuers ============="); return null; } public void checkClientTrusted(X509Certificate[] certs, String authType) { System.out.println("checkClientTrusted ============="); } public void checkServerTrusted(X509Certificate[] certs, String authType) { System.out.println("checkServerTrusted ============="); } } }, new SecureRandom()); SSLSocketFactory sf = new SSLSocketFactory(sslContext); Scheme httpsScheme = new Scheme("https", 443, sf); SchemeRegistry schemeRegistry = new SchemeRegistry(); schemeRegistry.register(httpsScheme); CredentialsProvider credsProvider = new BasicCredentialsProvider(); credsProvider.setCredentials( new AuthScope("localhost", 443), new UsernamePasswordCredentials(args[0], args[1])); // apache HttpClient version >4.2 should use BasicClientConnectionManager SingleClientConnManager cm = new SingleClientConnManager(schemeRegistry); DefaultHttpClient httpclient = new DefaultHttpClient(cm); httpclient.setCredentialsProvider(credsProvider); try { HttpGet httpget = new HttpGet("https://mycompanysites.com"); System.out.println("executing request" + httpget.getRequestLine()); CloseableHttpResponse response = httpclient.execute(httpget); try { HttpEntity entity = response.getEntity(); System.out.println("----------------------------------------"); System.out.println(response.getStatusLine()); if (entity != null) { System.out.println("Response content length: " + entity.getContentLength()); } EntityUtils.consume(entity); } finally { response.close(); } } finally { httpclient.close(); } } }
i have already imported is required.
i have set the authentication to be true and enabled,however it still mention that the authentication is required.
HTTP/1.1 401 Authorization Required
Response content length: 494
I am using DefaultHttpClient and set the credential provider.
on authscope I put to local,what could be wrong?
494 Security Agreement Required
The server has received a request that requires a negotiated security mechanism, and the response contains a list of suitable security mechanisms for the requester to choose between,[19]:§§2.3.1–2.3.2 or a digest authentication challenge.[19]:§2.4
the reason begin i need to do
basic authentication
with httpclient
and disableSSL
at the same time.
Well obviously that is wrong. SSL or not, HTTP basic authentication is not related to that.
Code:CredentialsProvider credsProvider = new BasicCredentialsProvider(); credsProvider.setCredentials( new AuthScope("localhost", 443), new UsernamePasswordCredentials(args[0], args[1]));
What are you telling the httpclient to do ? Only pass the credentials over when the your target host is localhost at port 443 ? Is that what you are trying to achieve ? Are you trying to authenticate against a web server running at localhost port 443 ?
Please read carefully HttpClient - HttpClient Authentication Guide, and see what is wrong with your code.
As for your Custom SSL Socket Factory, are you constructing that for any particular reason ? I told you HTTPS is not related to HTTP Basic/Digest Authentication.
no SSL,
but my https has got basic http auth as well.
no digest.
import java.io.BufferedReader;
import java.io.IOException;
import java.io.DataOutputStream;
import java.io.UnsupportedEncodingException;
import java.net.CookieHandler;
import java.net.CookieManager;
import java.util.List;
import java.util.ArrayList;
import java.net.URLEncoder;
import java.io.PrintWriter;
import java.io.FileWriter;
import java.io.File;
import java.net.MalformedURLException;
import org.apache.commons.codec.binary.Base64;
public class ichinga{
public static void main(String[] args) throws IOException,Exception{
try {
// Create a trust manager that does not validate certificate chains
TrustManager[] trustAllCerts = new TrustManager[] {new X509TrustManager() {
public java.security.cert.X509Certificate[] getAcceptedIssuers() {
return null;
// Install the all-trusting trust manager
SSLContext sc = SSLContext.getInstance("SSL");
sc.init(null, trustAllCerts, new java.security.SecureRandom());
HttpsURLConnection.setDefaultSSLSocketFactory(sc.getSocketFactory());
// Create all-trusting host name verifier
HostnameVerifier allHostsValid = new HostnameVerifier() {
public boolean verify(String hostname, SSLSession session) {
return true;
String webPage = "http://example.com";
String name = "admin";
String password = "password";
String authString = name + ":" + password;
System.out.println("auth string: " + authString);
byte[] authEncBytes = Base64.encodeBase64(authString.getBytes());
String authStringEnc = new String(authEncBytes);
System.out.println("Base64 encoded auth string: " + authStringEnc);
URL url = new URL(webPage);
URLConnection urlConnection = url.openConnection();
urlConnection.setRequestProperty("Authorization", "Basic " + authStringEnc);
InputStream is = urlConnection.getInputStream();
InputStreamReader isr = new InputStreamReader(is);
int numCharsRead;
char[] charArray = new char[1024];
StringBuffer sb = new StringBuffer();
while ((numCharsRead = isr.read(charArray)) > 0) {
sb.append(charArray, 0, numCharsRead);
String result = sb.toString();
System.out.println("*** BEGIN ***");
System.out.println(result);
System.out.println("*** END ***");
} catch (MalformedURLException e) {
e.printStackTrace();
} catch (IOException e) {
