How does duo Sim phone works?
missotah
My I ask how does duo sim phone work? Only can use 1 sim at a time or can concurrent use 2 sim at the same time?
Was thinking if 1 slot i can use a prepaid card and off the data then 2nd slot I postpaid data plan?
silencer22
it really depends on the phone itself.
but if you are refering to A7 duo, it does work in the way you specified
missotah
i like A3 for the slim and non phablet factor.
However thanks for informing me about A7.
I feel that the most cost saving way to fight playing telco for overuse data is to use the following:
1st slot : use prepaid plan off data - these $50 use 1 year kind. :p
2nd slot: use postpaid plan - pay $26 each month for 5gb data.
Intrinion
Senior Moderator
Senior Moderator
There is also one which is an export set, A5 Duo
Cheaper, but it is an exported set with no warranty.
