how much power i need ?
raysusan
base on the rig on my right....without 1080
how much watt psu should i get?
ZrE0_Cha0s
without 1080 maybe u get around 300W? provided ur cpu not OC and u are just surfing the internet/ stream video.
12122012
@ 5:20 he explains same system with higher watt psu, u r just wasting power.
yusoffb01
you will only use up to what the system use, not according to psu rating. I use a 300w psu on an atom system, power draw is 15w not 300w
12122012
that's only true when u r within the psu efficiency range 20%-100%. try using a 650w psu on your atom system and tell me if it's power draw from wall is still 15w. watch it again if u still don't understand.
gld998
ZrE0_Cha0s
Gold efficiency isn't a must and bronze efficiency is not a bad one. It's more base on your usage. If u on 24/7, most of the time u will consider gold or higher efficiently. But if u just turning on PC to use for like certain hours, maybe 8hrs, bronze is still good for such usage.
