coyote
- Sep 20, 2000
Those tried the B series and K series. Knows.
Before one hits 100km/h, you probably already reach a traffic light already...
A neighbour of mine is going for 2 weeks of work trip. We often see each other at the lift , the carpark , the fitness corner and sometimes when coming into the estate passing the guardhouse .
he is going off for work trip and asking me to help him startup and drive around to warm up the car . It’s a manual Honda Civic. I see the label at the back with the word “i-vtec”
I heard a lot about vtec kick in yo! I’m wondering how can I setup this effect?
Hmm got gear one... Gear one can reach 100 kph? Some most need 2-3 gear chnage to reach 100 kph and one will enjoy vtec open yooop 2 times to 100 kph... Those engines have high rev short gearing... So visiting 8-9000 rpm is common.Before one hits 100km/h, you probably already reach a traffic light already...
6k rpm hard to reach meh? I sometimes just step on accelerator and rev to 7k for my car to reach 100 km/h when joining expressway.I heard last time, Honda civic needs 6000rpm to activate vtec and Honda citi needs 4000rpm to activate vtec. Oh Singapore road, usually it may mean vtec is never activated till COE expired. On automatic transmission, it will likely switch to higher gears to achieve the higher speed first and before it hits 100km/h to activate VTEC... So, unless one persistently keeping speed way above 100km/hr, likely no chance.
So if you are BBFA, it will activate sooner.Google gemini says moi honda vtec activates around 4500-5000rpm, subject to load and throttle position
Now many car companies have valve timing and lift control. Vtec was famous because honda was the first to intro.A neighbour of mine is going for 2 weeks of work trip. We often see each other at the lift , the carpark , the fitness corner and sometimes when coming into the estate passing the guardhouse .
Haha. in Sg just use gear 1 for all small road, can hit vtec a lot of times.A neighbour of mine is going for 2 weeks of work trip. We often see each other at the lift , the carpark , the fitness corner and sometimes when coming into the estate passing the guardhouse .
I-vtec don't have vtec
The roar is intoxicating.Only type R have Vtec, kick in from 6000-6500rpm. The engine will sounds like it's tearing apart
First time I drove type R, once Vtec kick in I was sweating even with AC... It's exciting and scary because of roar or sound like the engine is tearing apart. The kick is very different from TC carsThe roar is intoxicating.
Is like someone use a pillow hit very hard on your back... Fun right... I driven my bil civic SIR with a B18C inside.First time I drove type R, once Vtec kick in I was sweating even with AC... It's exciting and scary because of roar or sound like the engine is tearing apart. The kick is very different from TC cars
i-vtec is the newer version. It's always active and continously variate the cam lobes and intake timings depending on how far the gas pedal is pressed versus the rpm.A neighbour of mine is going for 2 weeks of work trip. We often see each other at the lift , the carpark , the fitness corner and sometimes when coming into the estate passing the guardhouse .
