bornerwave
- May 25, 2013
by any chance does anyone know if i can add like a 600W power supply and put a palit gtx 770 on my motherboard? will there be any bottleneck or whatsoever?
hmmm i feel if u use virtual machine than 4GB not really enough.
So only if using virtual machine then will use more than 4gb if ram? How much performance improvement will a non-gamer feel if upgrade from 4gb to 16gb?
It all depends on what you do, really. Usually, 4GB should be enough, it won't improve gaming performance or make applications run faster.
If you're one who uses ram intensive programs like Photoshop, VMware, Virtualbox, or do a lot of video editing then an upgrade will be justifiable.
with your current set up?
there are some bottlenecks but the 4gb ram and 32bits windows will be a start, try and get 64 bits windows installed so you can upgrade your ram to something higher like 8bg(recommended) or 16bg.
after that you can change to a new PSU and GPU like i suggested in an earlier reply.
there are other minor bottlenecks but they are quite negligible for day to day use and gaming
you can also ignore my previous comment about SSD being bottlenecked by SATA 3gbps, they are also quite negligible for day to day use.
so its something like this
OS>RAM>other things(PSU+GPU/SSD)>the rest (MOBO+CPU)
i do use VMware very frequently to use my school virtual desktop for school work purposes. I also use sony vegas quite a lot due to the projects im having now haha
hmmm thanks for the steps! I have taken note of it! just asking, what do you mean negligible, does it mean that i am not using the full potential of the new hardwares due to the bottlenecks? where do the bottlenecks occur if i have finished upgrading to a 64 bit OS?
What he probably meant is that, though bottlenecks will exist with your upgrades, there will be little impact when it comes to gaming and normal daily usage.
yup
after win64 upgrade , the only bottleneck i can think of from MOBO are
PCIE 2.0(current one) vs PCIE 3.0( mainstream one) [GPU wise]
HARDOCP - Tables of Performance Advantage Percentages - PCI Express 2.0 vs 3.0 GPU Gaming Performance Review
jump to page 13, you can see that theres only a few fps different between those 2, difference becomes larger once you add more GPUs(SLI/CFX)
and
sata 3gbps vs sata 6gbps [if you are getting an SSD]
Real-World Benchmarks: Booting Up And Shutting Down Windows 8 - Is A SATA 3Gb/s Platform Still Worth Upgrading With An SSD?
Page 13,14,15 . again, a few seconds different between those 2..
Video test : https://www.youtube.com/watch?v=6bj3QT0UODc&gl=SG&hl=en-GB
thats what i mean by being negligible..
they will be "bottlenecked" by ur current mobo... but they are so minor you won't even notice them being there..
CPU wise... well, thats for another time till you want to upgrade it.
Then you'll probably find the ram upgrade very useful. Especially if you've got multiple VMs running simultaneously, though for Sony Vegas it'll probably be more taxing on the CPU.
normally my RAM already runs almost full capacity or i experience lag when opening just one VMware haha, i guess i will really need the upgrade!
Most likely u are using the page file for the VM. Or maybe the VM RAM usage is set to too high. can try lowering it.
After trying this out on my mom's PC (which really crawls).. old AMD proc, 2GB ram (maxed out), etc.
Putting in a SSD made a HUGE difference. SSDs are getting cheaper. Try getting a 64gb or 128gb one. The difference in performance is probably the biggest jump if you are changing only a single component.
Project question , using a corsair 800w power supply bronze gaming series, can i SLI 2 gtx 770 with a asus maximus v formula z77 chipset with inteli7- 3770 processor? will the computer be able to boot up, im afraid that there is not enough power
Yeah definitely. You can always google for a PSU calculator just to be sure.
