How to power my GPU?
Alexls
Im using a tfx power supply and it has 1 molex connector, 2 sata connector, and 2 4pin pcie connectors (1 for cpu, 1 no use)
My gpu is a 1060 3gb mini card and require 6 pin pcie
Gtx 1060 3gb power consumption is 120 watts, so after getting 75 watt from pcie slot, still need 45 watts
What adaptor should i use to power my gpu? Can i just plug the 4 pin connector into the 6 pin gpu? Or need to use molex-to-6pin adaptor etc?
Unic0rn
by using the adaptor to convert into 6pin?
how come your psu so chui no 6pins
wwenze
Rule of thumb:
If it doesn't have the connectors for it, it probably doesn't have the power for it
