How to select a correct power bank
{WuMing}78
Hi! I see a lot of power banks in the market, especially Qoo10.
However, I dun really know which one to choose.
I just want the power bank to charge my iPhone 7 Plus a few times and my iPad Air 2.
Please advise on how to choose a power bank base on its specifications.
Thank you very much in advance!
lucied
Suspended
Most important is to buy a reputable brand. Unless you want explosion (extreme cases).
Second is capacity. A phone now is approximately 3-3.5k mAh. So a 10k mAh power bank can charge your phone 3 times.
Third is Amp. More is better. Usually 2A-3A? should be good.
Fourth is how many devices do you want to charge at the same time. Buy more outputs if you need more.
TLDR: Buy the Anker powercore 20100 or 26800
royfrosty
There are many things you may need to consider first before purchasing a power bank.
Ask yourself this few questions.
1. Are you going to head out often with a power bank.
2. Are you traveling to overseas often with the power bank.
3. How many devices are you trying to charge.
You need to research more on the brands out there that is available. Some reputable brands are like Anker, LimeFuel, Ravpower, XiaoMi, Sony, Samsung, Aukey (used to but now questionable), and the list goes on.
Next is features that you need. But this is mainly for Qualcomm Quick Charge technology or USB C PD. Or ability to fast charge the power bank and lastly how many ports you need.
- Qualcomm Quick charge is for every Android phone out there that manufacturer pay license fees to Qualcomm to have the Quick charge function.
- USB C PD. Developed by USB themselves and it is commonly used for laptops, macbook, and other USB C devices such as Nintendo Switch, Google phones etc. This USB PD is a USB certified standard.
- Fast charging of power banks. This feature is really needed if your power bank has a big capacity. Some power banks allow Qualcomm Quick charge, while others allow USB PD, this helps you reduce your overall time to charge the power bank. Remember the differences, 10000mAh 5v 2A input charging will take 5hrs to charge full. While Qualcomm Quick Charge with 15w input could charge the power bank in within in under 3hrs.
- The number of ports needed are how many devices are you going to charge concurrently. Buy according to what you need.
Next is the number of times that will charge your devices. It will be a bit technical but I will try my best to explain as layman as possible. In this scenario we will take iPhone 7 plus as your device and a random 10000mAh power bank.
An Lithium Ion battery is only 3.7v. USB needs to be 5v in order to start charging your phone. So in between the battery to the phone, the power bank needs to convert from 3.7v to 5v. This is where unknown brands starts to get terrible at this portion. Some handle the conversion very well with minimal loss. Some handle badly till a lot is loss through heat output. A good reputable brands has the best circuit implemented in order to reduce losses.
So.... Once the power bank has to convert from 3.7v to 5v. You can no longer take into consideration of the advertised battery capacity stated on the power bank any more. You need to recalculate the actual capacity.
This is derived into this equation 3.7v * the stated capacity ÷ 5v
So a 10000mAh power bank on 5v charging will only have a true capacity of 7400mAh.
Hence an iPhone 7 Plus which has a capacity of 2900mAh. To get the exact figure on how many times can the power bank charge your iPhone 7 plus using the 10000mAh power bank?
7400/2900 = 2.55 times. This is provided you charge your iPhone 7 plus Everytime when it is total flat. In reality you can extend your mileage if you don't charge from flat.
So take your time. See what are your needs etc.
Hope I have explained correctly. If there is anything wrong, guys please let me know so that I can edit accordingly.
wwenze
There's also energy efficiency to consider
As in you need example 4.5V to charge a battery but the discharge voltage is 3.7V
Audiology93
Get the xiaomi 20000 gen 2 power bank. It's cheap and supports QC2.0 in case u use any android phones with QC2.0 in the future. Look for brands like Anker and Ravpower as well. If want to have a high capacity, get 1 with at least 10000mah.
Sent from NOTE 3 using GAGT
cscs3
Thats right. This is why a 10,000mA power bank will not be able to charge a 300mA phone battery 3 times. At most 2.5 times.
Also take in consideration if you buy those very high capacity power bank as you may need 5 to 7 hours to fully charge it. If you are travelling. You may not have this time.
So consider smaller capacity and/or those power bank with new QC technology. (same to the USB charger).
yusoffb01
Very good advices from all of you! Thank you very much!!!!
Saw these two options in Qoo10:
https://www.qoo10.sg/item/CHEAPEST-...TEBOOK-30000MAH-4/413106772?banner_no=1305330
And
https://www.qoo10.sg/item/HOT-MOBIL...-CHARGER-EXTERNAL/427018163?banner_no=1305330
Which one is the better choice for charging iPhone 7 Plus and iPad Air 2?
both are fake capacity and no quick charge. u see big numbers and cheap u fall for it.
the 50k mah is less than 20k, and the remax is aboit 10k. not that hard to tell apart fake capacity because battery density is not that great.
get the 20k xiaomi powerbank from lazada about $36.90 then use ladapp50 to -$7
{WuMing}78
Thanks for helping me. Would have fell for it if it wasn’t for your advice.
Saw another power bank, wonder if it is another scam:
https://www.qoo10.sg/item/FREE-LED-LIGHT-LAMP-ICOOL-50000MAH-QUAD-PORTS-4-USB-PORTS-WITH/432007770
Please help me to authenticate? Thanks in advance!
u0206397
Any expert here knows the average market rate price point for various capacities? For purpose of quick reference to spot any dubious/fake power banks with inflated claimed capacity.
  1. 10,000 mAh: $?
  2. 20,000 mAh: $?
  3. 30,000 mAh: $?
  4. 40,000 mAh: $?
  5. 50,000 mAh: $?
Andrew833
Best to buy 32,000 mAh and below for travelling, few countries have set their limit. Power bank need to have the amount of mAh and voltage written on the power bank.
royfrosty
There is no such thing as a market price for a power bank.
They are priced accordingly to their features they provide and the cells they used.
You see, XiaoMi 20000mAh vs Ravpower 21000mAh. XiaoMi is around $37 and Ravpower cost $72. But the features the Ravpower provides are much more versatile in terms of charging different devices.
USB type C input and output, 1 type A 2.4A, 1 type A quick charge 3.0, 1 micro input with quick charge compatible.
While on the other hand XiaoMi has only 2 type A ports with quick charge 3.0 and 1 micro input with quick charge compatible.
MoneyFace =p
But i doubt people will be willing to pay almost double for Ravpower.
Elijahonli
if u worried about buying fakes, and the cost, just pop in to the official xiaomi store and get a 20k. Should be enough for most users, since your iphone and ipad dont support quick charge, is should be fine
royfrosty
That depends. Cause to some they really wanna charge their laptops with the type c output. They are willing to pay to bring out something smaller and convenient rather than the adapter brick. If people can afford to spend so much on type c dongles for their apple macbook, to them this is small amount.
Besides that, qoo10 that time I got it for $3X with the right coupon.
Some powerbank has more than 5v 3A (15w) output. Such as USB PD certified, they are able to push far more wattage for laptops. Hence yeah.
In terms of more versatile charging it is better than XiaoMi.
XiaoMi to me is just cheap and just suffice for standard type of usage. But for me I can't use theirs simply I need type C input output and also a quick charge port at the same time.
royfrosty
Yes back to TS. If you strictly going to use just purely for apple products then get the gen 2 XiaoMi 10000mAh will do for travelling.
Then 20000mAh if you are a power user.
