How to turn off routing/set bridge mode on 2WIRE 5012NV
ghui64
hi guys
i still cant figure out how to get it connected to the internet
my connections are as folows
ONT --> 2wire --> TPlink router
i have already bridged the 2wire. then from 2Wires LAN point connect to TPlink router WAN point.
My tplink is able to get an IP address.
but i cant connect to the internet
thanks
ww2039
Using TP link 1043nd with 2wire in bridge mode, but router flashed to gargoyle firmware for 1 month without issue.
wrt54gs
If your 2Wire is not listing a computer with a static IP address, or you would like the 2Wire to act as a bridged router, the 2Wire offer the technicians pages to change advanced settings:
h t t p://{router ip}//tech/configuration.html
This will bring you into the advanced configuration for the 2Wire. If you have a server with a static IP, and the 2Wire does not have it listed, it will not forward network/internet traffic to that computer. You can reset your local area network’s computer list. This will force the 2Wire to start rebuilding the list again and re-detect your server.
This this problem become common, consider placing the 2Wire into bridge mode and using your own router. This will require a static IP.
Shawn Zernik
Internetwork Consulting
try tonight. thanks
victoryeo
Does anyone ever use the 2Wire in bridge mode with Aztech GR7000 router? Wantto use the 2Wire just for the ADSL modem only. No proble, to bridge the 2Wire but can't seem to connect to the internet.
ralph
problems with bridge mode
hi guys,
sorry for bumping this up..
i tried putting my 2wire 5012V in bridge mode to the RT N56u.
i did the following on the 2wire:
  1. disable routings
  2. disable wifi
  3. Disable DHCP
as per the instructions of this thread... but my boardband becomes disconnected and the N56u is not transmitting wifi as well.
anything i missed out??
i hv connected e n56u via wan from one of the 2wire lan port.
any specific settings required for the n56u as well?
thanks!!
Litmuss
hi guys,
  1. disable routings
  2. disable wifi
  3. Disable DHCP
thanks!!
Switch off ONT, router, and switch on again.
weap0nx
hi Litmuss,
thanks!
is there any settings required on the n56u?
or juz leave everything in its state?
It to totally transparent to the router, you can use any brand, any model no settings required except that you set it to DHCP mode
ralph
hi guys..
thks for the help...
it seems that under LAN/IPTV settings, i hv the singtel presets selected in bridge mode..
once i select none.. i can surf with e wifi from rt n56u...
micarforum
How's the performance of Singtel's fibre router (5012NV) in bridge mode compared to a higher grade modem or a total replacement like Asus N56U / N66U?
Wondering if I should do a bridge mode of singtel's modem + my own wireless router (Airport Extreme), or Just a Asus N66U, or a different brand's modem + Airport Extreme...
weap0nx
Technically no diff as bridge mode is L2, it's just a switch which handles the VLAN stuff for you. But last time when I used Singtel, bridge mode will break the MioVoice
lrrpie
Anybody know if it is possible to use the below configuration?
ONT -- Aztech 7000GRV(S) -- homeplug(living room)
Homplug(room) -- Pace 5012NV-002 (bridge mode and AP)
