Hp Envy h8-1580d help
moisuperman
Having problems trying to boot into bios. Pressed ESC and f11 and f12 etc . all can't .
As I'm trying to upgrade to ssd.
Is there a way, to install windows to the ssd using other PC and boot up on the HP envy?
When I insert the windows CD into the CD drive , it doesn't detect the disk.
Sent from LeMobile LE X820 using GAGT
ragnarok95
Senior Moderator
Senior Moderator
Press F10 to boot into Bios.
Not Esc, or F11 or F12.
moisuperman
Load the HP screen den straight into error
