Huawei 10 Pro or Samsung Note 8
Apewapew
Hi bro and sis...
any review for Huawei Mate 10 Pro or Samsung Note 8? am a Samsung user for many years.. saw some photo taken using Huawei Mate 10 Pro very chio...:s13:
ZrE0_Cha0s
if using phone for most photo taking will be huwawei 10 pro. but if budget allows goes for i0s
galaxyuser
Honestly depends on your needs.
Mate 10 is geared toward photography while Note8 is geared toward those who require the S Pen. So if you prioritise entertainment and photog then Mate 10 is for you. Otherwise if you favour productivity, go for the Note8.
This short explanation ignores the differences in price of the two phones. Note that Note8 carries more front facing features than the Mate 10. But on the back it's mostly the same if you ignore megapixel count and functions of the dual cameras between the two devices.
I shan't sway you or anything, you make the call yourself. Personally I'm a die hard Samsung fan so I'll still stick with Samsung no matter what. :s13:
delson_tan
I was in the same situation as you and went for Mate 10 Pro because of the 2 years warranty. Huawei also promises monthly update and it was a plus point for me.
cscs3
Update never happen anyway. For the price and battery life, I go for Mate 10 pro. But feature and software compatibility, Samsumg for sure.
