Huawei Mate 10
amazingone
Mate 10 gets EMUI 12 update! Jumped from 10 to 12 :s13:
amazingone
Which telco. Mine m1 don't have
Who still using this phone
I was using Circles on my Mate 10, but when I popped in my Malaysia SIM card to check its validity then the EMUI 12 update came in. :s13:
I guess the Malaysia SIM card made the EMUI 12 update available. Can try inserting non Singapore SIM card into your Mate 10.
dilphinus
The battery on my Huawei Mate 10 seems to be not able to hold charge after the updates.
I replaced the battery last year. Not sure if I should replace the battery again. This phone is entering the 5th year of usage.
Should I change the battery or get a new phone? This is my secondary phone. My primary (work) phone is the Redmi 9T. Am thinking of getting a 'better' new phone and switching the Redmi 9T to use as the secondary phone.
eyz
try resetting and use it as a fresh phone.
eyz
It seems like too much work and hassle for a 4 years old phone! Very tempted to get a new phone instead!
Thanks though!
mate 10 is 5 year old!
if you have a thumbdrive or pc, backup, reset and restore without apps data.
see whether you will find any differences.
