HUAWEI MATE 20 PRO ACCESSORIES
Skyy
why only pro? how about the rest of the mate 20 family?
flyingeagles
I'm trying to find privacy screen for m20p. Can't find on tb.. Anybody can recommend? Also do I need a Huawei cable and plug for super charge to work? I'm planning to have 1 set for travel.
Sent from Samsung SM-G955F using GAGT
twinraven
Yeap, need the original HuaWei ones to use SuperCharge
silversurfer
Try this cable. Able to supercharge using huawei charger.
PZOZ 5A USB Type C Cable Fast Charging Type-C USB C For ipad pro 2018 Huawei P20 P10 P9 Mate 10 9 xiaomi Charger USB-C data Cord
https://s.click.aliexpress.com/e/ZkC0LhW
flyingeagles
Is there any alternative to hw charger? Cuz I dw plug in and out the official wall plug/cable at home
deckcard
You should be able to find 22W HW charger quite easily but the 40W supercharge adapter (mate 20 pro) is new so you won't find any 3rd party selling them yet
shichuanhua
any1 interested in this,
planning to bring in some ~~
maybe @ $14 inclusive of normal mail
$17 with express shipping.
thomsonooi
you should get 2 supercharger plugs right? 1 with the phone and 1 with the wireless charger.
flyingeagles
Thanks! What's the difference between 22w and 40w?
you can get this, but its 22W instead of the new 40W charger. You still get supercharge.
https://www.aliexpress.com/item/HUA...lgo_pvid=b48c1916-41c7-4167-b8ec-0bb1d1a22ed7
I think will get this for the time being! Hopefully the supercharge works! Thank you!
Sent from HUAWEI MATE 20 PRO using GAGT
rojak_king_2005
For those who are waiting for the Whitestone protector for Huawei Mate 20 Pro, you can consider to try Invisible Shield. I am a whitesone user for S9+ and Note8. I wanted to get Whitestone for my Huawei Mate 20 Pro but my supplier said that the stocks will only be in end Nov or early Dec. So I decided to try Invisible Shield out to at least have a better protection. After using for 2 weeks, to my surprise it is really good and same as Whitestone. (May be can only tell the diff after dropping). However the price is just a fraction of it. Those interested can check it out in Qoo10. :)
tahoo
Any recommendations for cases? And screen and lens protector.
I worry for the curve screen....
White Shader13
Looking for a hybrid type case with clear back to see phone colour.
Been scouring the web but still none that offers decent shock protection with a clear back. If you know of one please post link!
leon0079
Limited choices :
https://sg.carousell.com/p/198533303
https://sg.carousell.com/p/199419590
https://sg.carousell.com/p/199665969
Sent from Huawei Mate 20 Pro using GAGT
