Huawei Mate 20
newuserid
Pro users, how are you adapting to the curve edges? It seems more curved to me vs S7E.
Easy to touch the sides accidently via your palm?
How's the side reflection? Seems to be quite reflective on the top/bottom.
ok with the edge
installed "always on edge" app, to have notification ring around the edges :)
thewiseone
Any weird rainbow pattern or issues with this tempered glass?
no it doesn't have any borders. it's just full glass with loca glue adhesive. similar to the whitestone dome but no brand, hence the cheaper price tag. i'm not saying it's the best and neither am i promoting it at all.
athenodorus
dunno why my led light is green when the phone is not fully charged (93% and still charging). shouldn't it be red? or is it a huawei feature again. lol. > 90% will be green?
Skyy
the green led is Huawei's way of telling you to disconnect the charger to prolong the life of the battery
tohchr
When I disable the Singtel SIM, and I tried calling using the Digi SIM, the phone will still try to use the Singtel SIM. I don't think it will turn it On because the call cannot go through. I will have "Cellular Network Is Not Available" error since the Singtel SIM was already disabled. Weird right?
U OK to do a full restore? Setup as new, leave everything as default, put in 2 sim cards as normal. Important point to take note is do not change the "default mobile data" under settings, wireless and network, dual sim. I suspect its the same bug that I encountered b4 on my P20 Pro.
townman
Btw, anyone manage to get the S health work with M20p? I'm talking in terms of the phone step counting. I understand previously that the S health doesn't track steps fr the HW phone when the phone screen is off.
Sent from Samsung SM-N950F using GAGT
I use 3rd party app Health Sync to sync from Google Fit to Samsung Health, that the only solution work for me on Mate 9
maur_james
The battery drain also depends on how many apps you have, that are/might be running at the backend even when you are not using.
