Huawei Mate 20
wrathbringer27
I have an LG screen but no issues thus far. Will update if there is any development on the screen bleed issue occur
sajokj
If anyone want to check the green screen issue in their pro then try this test change the YouTube Default theme to black grey, then go to dark room. You can see the green dots on edges. Checked on more than 4 pro phones, all have the issue
MrLampa
Mine ok using since last sat
1982-1994
Just use as normal lor.
Don't know why I find it hard to differentiate between HD and full HD+ on m20 but not on note 9.
Not sure is it due to display type.
TheCaffeEspresso
I realize even if I'm not watching. Leaving YouTube at background with screen off. It still drain alot of battery
Sent from HUAWEI Mate 20 Blue using GAGT
Tuakong
Is there anyway to change font size, style n color of the icons on the stock launcher?
maumu
just wondering how much of the current phones sold are affected. and also how do they know which are the ones affected so that they can recall all those still unsold before they are sold to customers.
exchange 1-1 is quick way to pacify customers but imagine if the new one still has the same issue then how many 1-1's have to be done until one which has no screen defects leh?
