Huawei Mate 20
Geros_Peters
Same here. Other than the initial screen protector and case issue, everything else has been great!
So far mate 20 Pro is great! Good battery life, super fast charging,good feel with loca and free casing, imba camera.
It has been years since I felt this awesome for a new phone. Never felt this for the newer iPhone after iPhone 5
gws898
Given a choice during qoo10 promotion, should I get ROG phone or Huawei Mate 20(non pro)?
The only thing on mate 20 is that i need to invest their memory card.
Sent from LG G7+ FookQ using GAGT
balzebub
Do you game? Hard-core gamer? If not then Mate 20 bah
kyleongwl
ROG? It is superb expensive... Tat cash can buy mate 20pro.
Question..
1. Do u game?
2. Do u like non conventional form factor
If yes to above, ROG
I uses mate 20pro for games... (pubg, forynite, asphalt..) are running well. On top, gd batt and nice camera
yhw22
you can try trigger but it's not free..
You can do it with automation apps like Tasker or automagic. I use the later mainly for my own automation scripts
Oh. Thank.
Found Trigger - Task Launcher is free. But additional task need not free.
Just need a simple turn on off wifi based on certain timing.
Sent from Sony G8142 using GAGT
athenodorus
Oh. Thank.
These kind of Tasker app, won't drain battery meh? Since it has to be in background all the time?
gws898
Bought the mate 20 on one store and huawei 256GB nm card on another store. Both together costs less than during the pre order.
kimwee
Can share link for the nm card? Thanks
